16" GT Wheels
Old May 14, 2008 | 12:23 PM
mcburns36's Avatar
mcburns36
Default 16" GT Wheels
Has anybody went with aftermarket 16" wheels on the GT? I am guessing this would give you more tire options than 17" The big question is , will they fit?
Old May 14, 2008 | 12:37 PM
rad_rob's Avatar
rad_rob
Default RE: 16" GT Wheels
You will run into clearance issues with the brakes. There are toooons of tire options for 17's.
Old May 14, 2008 | 01:36 PM
157dB's Avatar
157dB
Cut & Paste Expert
The GT brakes wont fit inside 16" rims.
You can degrade to V6 brakes and fit 16" rims, but why?
Old May 14, 2008 | 06:56 PM
mcburns36's Avatar
mcburns36
Thanks
Old May 14, 2008 | 08:07 PM
PLstang's Avatar
PLstang
I have 15" wheels on my GT. They are Bogarts and they were tight, had to remove the rear sway bar. However, they do fit with the brakes.
Old May 15, 2008 | 03:34 AM
Orion_240's Avatar
Orion_240
one says yes...
another says no...
Way to go Guys!
Old May 15, 2008 | 05:13 AM
JimC's Avatar
Super Moderator
I upgraded my front brakes to the bigger GT brakes - I can't see any way that a 16" wheel would fit the front. It is really tight on my 17" wheel. The back end is a different story - the V6 and V8 use the same rear brake set up and the 16" wheel fits fine back there. Are you saying you have the 15" Bogarts on the front PLstang? Unless you changed the front brakes I don't see how that would have fit the front - perhaps on the rear but not the front.
16" front - won't fit
16" rear - will fit no problem
Old May 15, 2008 | 07:35 AM
PLstang's Avatar
PLstang
Same Brakes and yes I have 15" wheels on the front!
jwog666
Dec 27, 2021 08:09 PM
UrS4
Oct 3, 2015 06:23 AM
mungodrums
Sep 28, 2015 10:54 PM
folivier
Sep 26, 2015 02:28 PM
lincolnshibuya
Sep 24, 2015 10:46 PM
