Retro S197??
Old May 23, 2008 | 02:05 AM
  #31
TOMBSTANG's Avatar
TOMBSTANG
Default RE: Retro S197??
ORIGINAL: AMoRT
ORIGINAL: bmk
that looks awesome!!!
dam I like the looks of that.
Pascal want to use my car as a dummy
Old May 23, 2008 | 02:06 AM
  #32
MustangBatman1's Avatar
MustangBatman1
ORIGINAL: TOMBSTANG
ORIGINAL: AMoRT
ORIGINAL: bmk
hell no, I offererd first
Old May 23, 2008 | 02:41 AM
  #33
TOMBSTANG's Avatar
TOMBSTANG
ORIGINAL: MustangBatman1
ORIGINAL: TOMBSTANG
ORIGINAL: AMoRT
ORIGINAL: bmk
ok deal them I get your rims cause cleary you wont be able to use them with that rear end ..........they just wont fit I can see it now.
Old May 23, 2008 | 06:45 AM
  #34
fairlane292's Avatar
fairlane292
Yup, the key phrase is "a ton of work". If you are doing the fabrication yourself though the overall cost when starting with a GTthat hassome panel damage will end upbeing just a bit more thanthe cost of that GT repaired. Fitting 67-68 qtrs and fenders to the S197 rear and front facsias would be a nightmare (and not a path worth taking; not one that would interest me anyway). The only S197 styling queues would be all the glass, roofline and door handles/lock. The gas filler could possibly end up in the 67-68 rear fascia panel location which would be quite "trick". ...maybe when I retire... this is a BIG job but the result would be aS197 (67-68) stang; YIKES...wayyyyy cool. "Fastforward Fastback" indeed.
Old May 23, 2008 | 07:40 AM
  #35
MustangGT0405's Avatar
MustangGT0405
Looks very interstesting.
What about making it look like a 68 GT390. Myabe highland green with a grille delete and a dent in the side?
That would be cool.
Old May 23, 2008 | 08:06 AM
  #36
cobraa99's Avatar
cobraa99
GOTTA KNOW WHERE DID YOU GET THOSE SIDE MIRRORS?
Old May 23, 2008 | 08:32 AM
  #37
cbrstng08's Avatar
cbrstng08
ORIGINAL: bmk
I thought you couldn't buy this kit, that it was unavailable. If it was i would definitlry get it.
Old May 23, 2008 | 08:36 AM
  #38
pascal's Avatar
pascal
S197 Section Modder-ator
ORIGINAL: fairlane292
I've done extensive jobs like these before... Put 2 front ends of a VW bug together when I was 17 in Europe. It was a blast to do too, hood on the front, hood on the back.
What scares you, doesn't necessarelyscare me (no offense).
The S197 door is about 53 inches long and the fastback is 49.
Also, my 06 doors are way taller. So the sides would require the most finesse as far as flowing lines.
The front is no big deal (considering) and the back will have the original tail panel (not the Shelby look) of the fastback.
That means, originalchrome bumpers etc...
The gas fillerat the rearis against the law nowadays, so that issue has to be adressed too.
This job depends on how cheap I can find a donor car...
I need to find a badly wreckedV6for no more than $2000.
A strong N/A push rod engine will find a cosy place in the engine bay.
And cobraa99, those are 71 mirrors with custom plates to fill the void left by the original ones.
Whit a keyless pad for nice touch. That's the mod virus for ya.
[IMG]local://upfiles/78700/C13592C802D8454CAF5958B297E8807C.jpg[/IMG]
Old May 23, 2008 | 08:55 AM
  #39
TPony's Avatar
TPony
Pascal, you da'man...your should work for Ford...no, wait a minute...they are firing folks right now. Never mind...
Old May 23, 2008 | 03:52 PM
  #40
pascal's Avatar
pascal
Thanks budd.
I'd work for Coletti.
This is one guy they should have pampered, instead of making him quit
