Sponsored by:
Sponsored by:
Help with idle...come on in guys
Old 06-15-2008, 01:28 PM
GT/SRT
GT/SRT's Avatar
Default Help with idle...come on in guys
I have just a quick question I think I might have actually seen here before.
I installed a Bamachips 93 tune the other day after putting on the CAI and had a small issue. When I put the car in neutral or kept it in gear and depressed clutch [either way you do it, it's when you're coming to a stop] and the revs would fall below normal idle to about or just below 500 rpm.
I called up Doug and he sent another tune that day, great guy. Anyway, it fixed it some but still does it a bit. Doug recommended that I get some throttlebody cleaner and clean around the butterflies in the TB and even spray it on the MAF sensor too. He said that in these cars sometimes there is buildup around the butterflies in the TB or dirt on the MAF sensor that can cause this issue.
Was just wondering if any of you guys had the same small issue [nothing big...but still] and if doing the above took care of your problem. Thanks.
GT/SRT is offline
Old 06-15-2008, 01:31 PM
howarmat
s197 Junkie
howarmat's Avatar
Default RE: Help with idle...come on in guys
check all connections for the CAI....very common problem, then clean the TB blades and MAF if you still have some troubles
howarmat is offline
Old 06-15-2008, 01:52 PM
mx07gt
mx07gt's Avatar
Try loading up the stock tune, and then re-loading the bama tune...
worked for me.
Hope it helps!
mx07gt is offline
Old 06-15-2008, 04:12 PM
GT/SRT
GT/SRT's Avatar
Thanks guys. It's nothing big, just want to get it taken care of.
I'm also going in tomorrow to have my gears replaced...the 4.10's I have whine a lot in 5th gear and some in 4th so the guy is replacing them for free.
I can't wait to get them in and go through the 500 mile break in...REALLY want to see what 1st gear is like after the tune, new tires and 4.10's[8D]
GT/SRT is offline
Old 06-15-2008, 04:16 PM
mlcrycc
mlcrycc's Avatar
Yeah, cleaning the TB helped with my idle, as well as first gear take off....But, I'm not too sure I would use TB cleaner on the MAF.....
JMO,
Mike
mlcrycc is offline
Old 06-15-2008, 08:11 PM
GT/SRT
GT/SRT's Avatar
ORIGINAL: mlcrycc
JMO,
Mike
That's just what I was told by Doug at Bamachips
GT/SRT is offline
Old 06-15-2008, 08:24 PM
Vertigo
Vertigo's Avatar
I cleaned the TB and my sensor with the correct cleaner for each and it fixed my problem. OH and i moved the shield on my intake to the proper spot.
Vertigo is offline
Old 06-15-2008, 09:55 PM
GT/SRT
GT/SRT's Avatar
What type of cleaner would I buy specifically for the MAF sensor if the TB cleaner won't do it?
I would imagine it would for Doug to tell me that...but what have you guys used?
GT/SRT is offline
Old 06-17-2008, 06:55 PM
danam
danam's Avatar
I have same problem on my 05 Roush. It's almost stalling. Dealer is going to look at it on Thursday, under warranty, but they told me its very common and its a bad sensor that causes this.
danam is offline
v8sn95
09-07-2015 10:17 AM
Mustangmalo
09-06-2015 05:22 PM
SilverStallion05
09-05-2015 10:48 AM
Emblazoned
09-03-2015 10:45 PM
Quick Reply: Help with idle...come on in guys
