ODB2 Fuse
Old Jun 17, 2008 | 06:45 AM
goharv's Avatar
goharv
Default ODB2 Fuse
My CE light was on and ran down to AutoZone to get the code. They said my ODB2 Fuse was blown and that was causing the light. I have looked through the owners manual and online, but haven't found the ODB2 fuse location. Does anyone have any help on where it is located?
thanks
Old Jun 17, 2008 | 07:13 AM
rlh6805's Avatar
rlh6805
Default RE: ODB2 Fuse
ORIGINAL: goharv
thanks
Not true. The OBDII fuse is only for power at the diagnostic port, it has nothing to do with setting the CEL. More than likely, when they plugged in their diagnostic scan tool, there was no power at the J1962 (diag port) under the dash. Their tool did not power on and the dumb *** parts guy gave you that line of BS. The diag power circuit is usually shared with the power point circuit. Do you have power at your in dash power point (cirgarette lighter)? Doesn't matter anyway because all of the good diag scan tools will allow you to plug into the diag port AND get power from another source (jumpers to the battery terminals). Take your car to a real service shop and have a real tech diagnose your CEL problem.
Old Jun 17, 2008 | 10:02 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: rlh6805
ORIGINAL: goharv
thanks
+1
http://iihs.net/fsm/?dir=40
OBDII is powered on its own circuit/fuse
jwog666
Dec 27, 2021 08:09 PM
daytooday
Sep 20, 2015 10:55 AM
wenmill
Sep 11, 2015 07:07 AM
cbird1177711
Sep 2, 2015 04:12 PM
