Steering Wheel Shake?
before you go get your tires re-balanced, do you have centering rings? i use em on both sets of my am wheels. they're plastic rings ~2-3" in diameter that fit around the hub, ensuring a snug fit when you mount the wheel. my steering wheel shook badly above 50 mph before i installed the rings.
do the American Muscle wheels require centering rings? i thought they did not. i cant do the front and back switch since its 255front and 285rear but i have tried my other set of wheels tires and have the same problem
try torqing your wheels in the pattern shown in owners manual, i think it is 100lbs. I had this problem too, i took lugs off and reinstalled and torqued in sequence and problem went away.
ORIGINAL: SatinSilverStang
i had the same problem with the wheels i bought from them, just curious, how much weight did it take to balance your wheels i have rows of weights on mine and the one wheel has weights stacked on top of each other
ORIGINAL: Nuke
FYI, the RoadForce balance will help identify a tire or wheel that's out-of-spec. Once the RoadForce balance determines that all is well, then a standard spin balanceshould beall that's required.
My guess is the rotor clips ("keepers") shown above.
Yea, I knew that Nuke. I was speaking of the lug centric balancing that balance just as if it were on the car.
jwog666
Dec 27, 2021 08:09 PM
mungodrums
Sep 28, 2015 10:54 PM
mungodrums
Suspension
Sep 24, 2015 10:12 PM
