getting bundle of wires thru the firewall
im installing my gauges on the a-pillar. i need to get my wires thru the firewall on the driver side,up high as possible. i have the cluster pulled out right now to look. i have already used the hole down low for alarm wires. any one have any suggestions before i waste my time looking? i spotted one up high but im not sure if it just runs into the wiper channel or if it actually goes into the cabin.
RE: getting bundle of wires thru the firewall
When I installed gauges I just used that hole behind the clutch pedal there's a rubber boot there that goes into the wheel well and thats where I ran everything through. Not sure if that's what your talking about but there seems like there would be plenty of room for many wires, the rubber boot is about the size of a hockey puck. That's the only practical place I saw.
ORIGINAL: one eyed *****
awesome,ill have to take a look at that!
I don't know if your car is an '07, but on the '05 there is a soft, black sticky pad about 1/4" thick on the firewall above where the clutch pedal would be. It's rectangular shaped and covers a hole in the firewall that leads directly in to the engine compartment. It's an easy push -through.
thanx alot guys.i took the wheel off today and pulled the inner fender out.that plug you guys are talking about was the same one i used when i did my alarm.i didnt realize i was just looking at the inner fender when i looked through that grommet.i thought it was more firewall,lol,so with the inner fender out of the way it was a piece of cake.thanx again.
jwog666
12-27-2021 08:09 PM
Matt's 95 Stang
10-05-2015 07:16 AM
