Off Balance Flywheel, Harmfull?
I just got my car back from the trans shop yesterday. My dad picked it up for me because i was working and said it drove a little " funny" He said it was "noisy and Vibrating". So i ran out all happy, jumped in, and pressed the clutch in, and it went straght to the floor. After pumping 20 or so times, i got pedal back but spongey. After more pumping it was better< problem one. Then, i went out for a drive and noticed it was REAL chattery, almost like they didnt resurface the flywheel even. I know a new clutch will take time for break in and wear but this was rediculus<- problem 2. I called them right up talked to the owner and he told me to bring it up and i was there 15 mins later and the shop was LOCKED UP and closed with noone there. I Ended up being more mad at them than anything and DONT even want to take it back. They had the car for 3 weeks to change a clutch and put in a new throwout assembly. The car does shift real nice with the new steeda, but i can tell that the flywheel is off. With the car in neutral, a 4k RPM rev will vibrate the car and shako in accociation with the RPM's that it never did before. When taking off it feels like it has a grippy spot on the flywheel. It doesnt seem to bad and ive already taken it up to 6800 rpm a few times and it does fine, but shakey. I just wanted to save myself a few hours in the garage, by having someone else do it, Now i will have to do it myself anyways. And im sure it will be done in 1 weekend and not 3 weeks. Do you think the car is safe to run with a flywheel a tad out of balance, or should i not even stress my clutch and just drop the trans and put in a NEW flywheel? Could the vibrating potentially hurt anything else? -Jon
Are the Flywheels on our cars located on the crank in a certian way? Do they ride on a hub, or doweled, do the bolts line it up. Im wondering in the shop just didnt put it on correctly. They told me they " send out there flywheels" to be surfaced somewhere else. Im going to end up just picking up a new one anyways. -Jon
junior04
Sep 28, 2015 10:53 AM
ccdguy
Sep 19, 2015 05:20 PM
LivingInThePast
Sep 16, 2015 12:20 PM
