2v.. 3v.. 4v..
Old Jul 24, 2008 | 06:16 PM
blueherd02gt's Avatar
blueherd02gt
Default RE: 2v.. 3v.. 4v..
Niether...
330 cu/in 5.4l 32v gt500 is the best.. Unless you got the nads to build the 351 cu/in v10 motor
Old Jul 24, 2008 | 06:29 PM
mpatilla's Avatar
mpatilla
So what do the stangs come stock with? The V8 and the V6.
Old Jul 24, 2008 | 06:40 PM
jz's Avatar
jz
ORIGINAL: mpatilla
v6's are two valves per cylinder, v8's are 3 valves per cylinder
Old Jul 24, 2008 | 06:41 PM
AK_Kayaker's Avatar
AK_Kayaker
ORIGINAL: blueherd02gt
Niether...
Ok so that reinforces that the 4V is the best.
Old Jul 24, 2008 | 06:44 PM
Elwood's Avatar
Elwood
ORIGINAL: mpatilla
96-04 GT 2v 4.6 v6 3.8 OHV 3.8L
05-Present GT 3v 4.6 v6 SOHC 4.0L
96-04Special models (Cobra/Mach 1) 4v 4.6
07+ GT500 4v 5.4
Old Jul 24, 2008 | 07:30 PM
Allstar's Avatar
Allstar
now i understand.. so techincally speaking.. the mroe valves the less airflow in each valve but over all you get more because you are utilizing more space within that cylinder giving you an overallmore air flow
Old Jul 25, 2008 | 06:44 AM
lieu910's Avatar
lieu910
ORIGINAL: AK_Kayaker
Niether...
Not nessecarily. The three valve head is lighter, and will flow just as well as the 4v head while providing better torque down low.
Old Jul 25, 2008 | 08:40 AM
Virgule's Avatar
Virgule
This is the most lame discussion I've ever seen on this board. Next we'll be discussing what the V in V8 stands for........
Old Jul 25, 2008 | 08:53 AM
Allstar's Avatar
Allstar
ORIGINAL: Virgule
oh shut up.. i told you i kno what the v in 2v 3v and 4v stands for i just didn't know how it worked.. excuse me..
why dontbu explain the cure for cancer since ur so smart
Old Jul 25, 2008 | 08:54 AM
Grabber's Avatar
Grabber
You do know that the 4V heads still flow better than 3V heads, even though it is close. Now, as far as torque down low, 99/01 Cobra's with the 4V have a better torque curve, same with the Mach 1's. Especially the Cobra's, they get all their torque at once at 2K RPM.
So, now, the Torque is not better on the 3V's. I own both cars.
So, 4V>3V>2v
