Installing Steering Wheel
Old Jul 31, 2008 | 05:38 PM
bigmac5300's Avatar
bigmac5300
Default Installing Steering Wheel
Just purchased a IUP upgrade Steering wheel off ebay for my 2006 GT. Just wondering if anyone replaced their steering wheel, themself and or let a garage do the work(cost?) Or any Existing Post on the install.
Old Jul 31, 2008 | 07:47 PM
Hootna's Avatar
Hootna
Default RE: Installing Steering Wheel
Fairly simple. Disconnect the battery so you dont get the airbag blowing your face off. Remove the two plugs on the sides of the steering wheel and remove the bolts. The airbag would not come out until I actually picked the loose bolts out of the hole with a needle nose even though they were completely loose. Pull the airbag out and there are two wire harnesses you unplug. Now unplug the other wires for the horn etc. Then get a socket with an extension and loosen the bolt and pukk off the wheel. Oh and dont be an idiot like me I put it all back together hopped into my car to go to work and found out the wheel was not centered. So test it before you tighten it all back up. Good luck.
Old Jul 31, 2008 | 08:14 PM
Goldenpony's Avatar
Goldenpony
Let me add a couple of things. Disconnect the neg. battery terminal and I'd let it sit for maybe 20 min.. If you want to be super safe (nobody wants their face blown off), the Ford procedure also wants you to pull the airbag fuse from the pass. side kick panal.
Again, according to the procedure, you should use a NEW steering wheel bolt, they are a one time use bolt. I got one from the dealer, I think it was like $3 or something. I felt better replacing it.The steering wheel bolt torque is 41 lb/ft.Whether you do this, up to you. It's not a tough job, just be safe with that airbag. Not only will they take part of your face off, they're about $1500 to replace. Enjoy your new mod!
Old Jul 31, 2008 | 10:40 PM
PennState's Avatar
PennState
dont scare him, i didn't take my battery out or remove the fuse, and i also never got a new bolt, and everything is fine..
Old Aug 1, 2008 | 05:06 PM
bigmac5300's Avatar
bigmac5300
Thanks everyone for the info
Old Aug 2, 2008 | 11:57 AM
157dB's Avatar
157dB
Cut & Paste Expert
http://iihs.net/fsm/?dir=137&viewfil...ng%20Wheel.pdf
Old Aug 2, 2008 | 12:47 PM
Joolander's Avatar
Joolander
Lord High Protector
if you would liketo post a write-up, that would be helpful
we could always use more writeups
Old Aug 2, 2008 | 01:40 PM
Goldenpony's Avatar
Goldenpony
Not trying to scare anybody, but you never have to apologize for doing it right.
Old Aug 2, 2008 | 02:13 PM
A_Drunken_Llama's Avatar
A_Drunken_Llama
I know there's many people who wanna switch to the Bullitt style steering wheel....so a write up would be appreciated from anyone who has done this
Urambo Tauro
Dec 17, 2016 03:30 PM
squishbang
Dec 4, 2015 02:29 PM
SYNY5TER
Sep 2, 2015 01:35 AM
kdryan
Aug 29, 2015 09:57 PM
Careless00045
Aug 29, 2015 10:44 AM
