Weight reduction.
Old Aug 2, 2008 | 02:03 PM
Pwny's Avatar
Pwny
Default RE: Weight reduction.
By Rygen:
Details:
46.5 lbs Passenger Seat
3.5 lbs Jack
29 lbs Spare tire
7 lbs Trunk mat
1 lb Passenger side floor mat
12.5 lbs Bottom of backseat
Getting rid of all of the above = 99.5 lbs savings
40 lbs OEM torque converter(with fluid)
39 lbs OEM driveshaft (GT info, need info for V6)
31 lbs OEM H-pipe with cats (GT info, need info for V6)
31 lbs OEM mufflers (pair)
31 lbs OEM battery
27 lbs OEM Pirelli without rim (GT info, need info for V6)
22.8lbs Truetrac 31 spline
21.5lbs (each) front stock strut+spring assembled - no spindle bolts - strut+spring+upper bearing plate/bushing
21 lbs OEM 17x8 rim
18 lbs OEM exhaust manifolds (pair) (GT info, need info for V6)
17.4lbs CHE Axle Brace w/LPW Girdle and bolts
17 lbs OEM Dual amps (behind the shaker 1000 boom box)
16.8lbs (each) Moser Axle - solid 31 spline
14 lbs OEM LCA's
14 lbs OEM front sway bar with end links
14 lbs Odyssey 680 battery
14 lbs (each) Eibach front adjustable srut+spring (pro-street-s)
12 lbs SLP Loudmouths (pair)
9 lbs OEM axle tube weights (pair)
8 lbs OEM crank pulley
6.2lbs CHE PHB
6.2lbs CHE DS loop (front only for a 1pc ds)
6lbs Front plastic inner wheel wells
5lbs Steeda steel strut tower brace (part # 555-5716)
5lbs Trunk trim (sides pannels & platic piece that cover the lower latch) & both struts
4.5 lbs OEM radio/CD player
4 lbs OEM UCA
3.8lbs CHE UCA (adjustable)
3.6lbs (each) CHE LCA
Source: http://www.mustangcollective.com/sho...d.php?p=211324
Since when was m u s t a n g c o l l e c t i v e . c o m a bad word?
Old Aug 2, 2008 | 02:18 PM
2008gtcs's Avatar
2008gtcs
actually this is a weight transfer idea - move the battery to the trunk. Back in the day we used to get group 27F (BIG battery) trunk install kits and put near/over rear wheels and install alum intakes with tubular headers. A person could jettison about 40 lbs and transfer about 60 lbs. But that was when you needed those big batteries to turn over a 390/428. now after all that, IMO the 4.6/5.4 are MUCH better engines, light and powerful.
On race day, empty your windshield washer fluid - a gallon of water weighs 8.3 lbs. Mustang capacity is 2.1 qts. You can get rid of 4.36 lbs compared to a full washer bottle. While I'm at it - get a Bullit grill and get rid of a couple pounds of fog lights, front lic plate and bracket (drag) take off the front spoiler, rear spoiler, fake scoops and get a shorty antenna - or no antenna (more drag) and any other hoo haa not contributing to performance or adding drag at speed. Last but not least - if you are a big guy, lose a few LBs. LOL, ...get Healthy - go Faster
Old Aug 2, 2008 | 04:46 PM
Bullitt#3949's Avatar
Bullitt#3949
lo carb diet ?
Old Aug 2, 2008 | 04:55 PM
Kaldar142's Avatar
Kaldar142
ORIGINAL: 157db
Maybe put the occupant on a diet as well?
Just looking for ideas here.
lol
5'8 135lbs
Old Aug 2, 2008 | 04:57 PM
Kaldar142's Avatar
Kaldar142
"12.5 lbs Bottom of backseat "
are you talking about the cushion for the backseat or is there something underneath the backseat?
ORIGINAL: alloutt
so do I
Mine are about to go bad
they have gotten lose over time witch makes the rearend sloppy
just a warning they will go bad
and will need to be replaced
yeah, i have the same problem... it SUCKS.
i'm wondering if i should just get some with spherical ends or replace the bushings?
Old Aug 2, 2008 | 05:17 PM
ReaperGT's Avatar
ReaperGT
I got you all beat on the least occupant weight. Try and keep up.
Old Aug 3, 2008 | 01:43 AM
alloutt's Avatar
alloutt
ORIGINAL: Kaldar142
ORIGINAL: alloutt
so do I
dude I was wrong I have spherical ends and they are getting sloppy I am just going back to stock i know i suck
I just can't stand the way it feels when I try to drift or do donuts can't control it anymore
Old Aug 3, 2008 | 03:07 AM
Phya's Avatar
Phya
ORIGINAL: ReaperGT
Guys, don't get too competitive with this now...
If you really want to compete for smallest driver, go find these guys.
Sorry about the OT post.
As an aside, we should have some sort of sticky that outlines all the possible weight reductions, if we don't have one already.
Old Aug 3, 2008 | 09:28 AM
timothyrw's Avatar
timothyrw
switching to boomtubes is supposedly a 16lb weight savings. i believe it, they were a lot lighter then the stock mufflers.
Old Aug 3, 2008 | 09:53 AM
Kaldar142's Avatar
Kaldar142
ORIGINAL: Phya
ORIGINAL: ReaperGT
I think we should sticky this thread as it already contains a good amount of info on weight reduction, and much more to come as i WILL be doing weight reduction.
