5.0 stroker kit?
Old Aug 6, 2008 | 08:48 PM
forensicsteve's Avatar
forensicsteve
Default RE: 5.0 stroker kit?
Very happy with the MMR 5L stroker model 950. Works very well their stage II heads/cams. Performing nicely under high boost levels and now starting to add nitrous. No issues at all.
Old Aug 7, 2008 | 09:55 AM
rad_rob's Avatar
rad_rob
ORIGINAL: HaneyMotorsport.Com
xROB- Please feel free to give me a call. I am more than happy to go over the details of our rotating assembly and other components that are needed/recommended. We do have pistons available in STD. and .020 over.
Saleen's stroker uses the same manufacturer as we do for the cranks.....KPC. Saleen gets 302cid from using their 3.80" stroke with stock bore. Our 3.75" with stock bore is 298 ....301 with a .020
I do believe there is some clearancing neede for the 3.8 stroke. We prefer the 3.75 and our 6" rod for the best rod ratioin the stroker mod motors.
Casey
Ill for sure give you a call once I get a little closer to being ready. What kind of numbers would I be looking at with your kit? Say if I decide to do the kit with the stock sized pistons, it would basically just a matter of changing out the rotating assembly right?
rad_rob's Avatar
rad_rob
Oops...I meant numbers as in HP. haha. We can talk prices when I give you a call.[8D]
Old Aug 7, 2008 | 10:40 AM
08StangGT_CS's Avatar
08StangGT_CS
xROBxCOREx, let me know what info you find about this since this is a mod that has been dancing around my mind for quite a while.
Old Aug 7, 2008 | 11:11 AM
ChiDiddy's Avatar
ChiDiddy
i would love to say i have a 5.0 too
jwog666
Dec 27, 2021 08:09 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
mungodrums
Sep 28, 2015 10:54 PM
treesloth
Sep 28, 2015 07:03 AM
