Keyless entry dosnt work anymore.
You might be wrong there.
I have an 07 with the 07 owners manual.
I programmed 4 keys and 4 remotes to mine.
It didnt require the two keys to program the remotes, just one key.
http://www.motorcraftservice.com/pub.../07musog1e.pdf
Maybe I'm thinking about the KEY programing... My bad.
Here it is. You have to reprogram all the remotes:
Note:
activated.
If more than 20 seconds have passed you will need to start the
procedure over again. The doors will lock, then unlock, to confirm that this remote entry transmitter has been programmed.
And here's where I saw the thing about 2 keys. I KNEW I wasn't going crazy (yet):
Only use SecuriLock" keys.
You must have two previously programmed coded keys (keys that already operate your vehicle’s engine) and the new unprogrammed key(s) readily accessible.
If no previously programmed coded keys are available, you must take
To reprogram the remote entry transmitters:
1. Ensure the vehicle is electronically unlocked.
2. Put the key in the ignition.
3. Cycle eight times rapidly (within 10 seconds) between the 1
(OFF/LOCK) position and 3 (ON).
Note:
The eighth turn must end in the 3 (ON) position. The doors will
lock, then unlock, to confirm that the programming mode has been
activated.
4. Within 20 seconds press any button on the remote entry transmitter.
Note:
5. Repeat Step 4 to program each additional remote entry transmitter.
6. Turn the ignition to the 1 (OFF/LOCK) position after you have
finished programming all of the remote entry transmitters.
Note: After 20 seconds, you will automatically exit the programming mode. The doors will lock, then unlock, to confirm that the programming mode has been exited.
Programming spare keys
You can program your own coded keys to your vehicle. Please read and understand the entire procedure before you begin.
Tips:
• You can program your own coded keys to your vehicle. Please read and understand the entire procedure before you begin.
Tips:
A maximum of eight keys can be coded to your vehicle.
your vehicle to your authorized dealer to have the spare key(s)
programmed.
YADA, YADA
