stereo system
Old Sep 4, 2008 | 08:30 PM
  #21
shanec's Avatar
shanec
Originally Posted by r3velation
is everyone just upgrading the system without putting the sound-deadening material? just wondering cause i don't seem to be reading anything on anyone putting that in except for a few cases.
i'm guessing it'll sound fine just upgrading because it seems like most are just swapping speakers/systems.
I think that stuff really comes into play when you put a sub in the trunk because your rear quarters and trunk can rattle like crazy.
Old Sep 4, 2008 | 11:01 PM
  #22
r3velation's Avatar
r3velation
my doors rattle like crazy. i sometimes like to listen to music and drown EVERYTHING out.
i can't even set it to like 6 full bars without a rattle, so i just turn it down, or open the windows turn the set off and just run like wild.
btw, what's everyone's speed volume at? i'm running 6
Old Sep 5, 2008 | 07:14 AM
  #23
06elnr's Avatar
06elnr
I put sound deadner in mine while I had it apart for paint and it made a big difference, I went with all kicker mids and highs running on the factory amps and 2 12s running on a memphis 1000d.
Old Sep 5, 2008 | 08:12 AM
  #24
CutterWolf's Avatar
CutterWolf
Where did you place your sound deadner at? Just the doors or else where too?
Old Sep 5, 2008 | 12:21 PM
  #25
jahudso2's Avatar
jahudso2
I deadened my doors, trunk, and rear decklid and it made my speakers sound awesome. Then I deadened under the rear seats, the center console, and the front fenders and now the speakers dont sound as good. They are still better than they were before the deadener, but I dont know what happened.
Old Sep 5, 2008 | 01:46 PM
  #26
black08mustang's Avatar
black08mustang
so this is what im planning on doing...2 10 inch subs an amp and a new alpine headunit...im on a short budget so changing out the speakers isnt right now but down the line sometime...im not sure what subs or amp im gonna go with yet..any suggestions???
Old Sep 5, 2008 | 10:42 PM
  #27
shanec's Avatar
shanec
You do not need 2 subs. One sub powered by a bridged (creates one higher power channel instead of 2-channel stereo) amp output like a Rockford Fosgate is a lot more powerful than 2 subs powered by 2 weaker channels. Cheaper 2 since there's only one sub.
Once I had 2 subs powered by a 2-channel Rockford Fosgate amp. Then a guy at the car audio store said "watch this". He bridged the amp and connected only one sub. It sounded 10x better than what I had before. I rode around with 2 subs with only one of them playing music. Later, I build a smaller box for 1 sub and sold the other sub.
Old Sep 5, 2008 | 11:54 PM
  #28
TheRebel's Avatar
TheRebel
Do yourself a favor and get a Class D amp for subs. It is internally bridged and usually stable to lower OHMs.
Old Sep 6, 2008 | 12:15 AM
  #29
lrgnation's Avatar
lrgnation
Mounting the amp to the backseat is about the most half a$$ thing you can do. It's a seat not any type of location that was designed for strength to hold something by 4 tiny screws. Use the rear deck if you want something stealth amps can be mounted upside down and you can use small bolts to make sure they dont come out. But I used self tapping screws and my jl audio 500/1 has been secured without fault for about a year. Before that I had an amp rack i built.
bradleyb
Nov 27, 2015 07:50 PM
jrrhd73must
Oct 2, 2015 09:17 PM
breaking
Oct 2, 2015 01:27 PM
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
