Sponsored by:
Sponsored by:
gone batty with the mods bug
Old 09-11-2008, 01:03 AM
  #21
deekum1627
deekum1627's Avatar
nelias were in new york are you im on long island
deekum1627 is offline
Old 09-11-2008, 09:25 AM
  #22
nelias7306
nelias7306's Avatar
i live upstate
nelias7306 is offline
Old 09-11-2008, 09:42 AM
  #23
deekum1627
deekum1627's Avatar
o very nice well good luck this weekend with the install man cant wait to see it done
Old 09-11-2008, 10:25 AM
  #24
avengence
avengence's Avatar
I am going to be replacing my gears with 3.73's. I know its not a big step up but my friend is getting rid of his and he has a spare install kit so I figured we might as well do it. I am going to do it myself as well, shouldnt be too hard.
avengence is offline
Old 09-11-2008, 09:26 PM
  #25
nelias7306
nelias7306's Avatar
nice!!!! go for it man i'm just frustrated right now cause my install kit hasn't come in ans that's all i need to get started... if i don't get it by friday i'll be pissed cause next week i work all week
just make sure you have the specific tools like a dial indicator with magnetic base, a micrometer, a torque wrench that measures inch pounds and maybe a pinion depth measuring tool
understand what pinion depth (very important to get it right or you gears will whine), backlash, and running torque/preload are before you attempt it and how to measure and adjust them. there are lots of websites that explain that and www.fordmuscle.com has an awesome tutorial on how to swap one out of an 05 stang
also know how to interperet the mesh pattern
once you got all that do it!!!
Old 09-14-2008, 09:39 PM
  #26
nelias7306
nelias7306's Avatar
here's an update
4.10 is in!!!!! took me all weekend. i drove it and there is an ever so slight whine on acceleration while driving in fifth above 2500 rpm (about 63mph) so i'm going to have to check my pinion depth. I read that the 4.10 whines but i think if you install it right it shouldn't. i ordered a 30 dollar tool that checks if you got the right shim on so I'm gonna do that next week. so far i've spent about $200 including cost of ring and pinion cause i bought a press from harbor freight to press the bearings on cause i didn;t trust using a hammer. i also bought some piping from home depot to push the bearing on
the pinion from ford had a value of 8 on it an that means you add 8 to .03 an that is the shim size. i guess maybe the bearings threw the depth off cause my backlash was 0.09 which is within spec
the biggest pain in the **** is getting the stupid differential back in but i'd rather do that than let it sit installed wrong.
i'd say that this job requires some special tools and is not easy but doable
after i determine if i need a different pinion shim i'll redo it and then post all the pics... won't be till nest week though good thing it's not my daily driver
Old 09-14-2008, 11:44 PM
  #27
deekum1627
deekum1627's Avatar
good luck with that man and just wondering if you painted the rear end up nice
Old 09-15-2008, 11:26 AM
  #28
avengence
avengence's Avatar
How does it drive now? A lot faster feeling?
Old 09-16-2008, 05:09 PM
  #29
nelias7306
nelias7306's Avatar
definitely faster and i can let go of the clutch and it won't stall easily.
my shim size was too small by the mesh pattern i have a feeling i might be able to use the orginal shim. once i get it setup right i'll post the rest... don;t wanna do a write up on how not to setup your differential correct
Old 09-16-2008, 05:11 PM
  #30
nelias7306
nelias7306's Avatar
now that i got it out again i'm gonna paint it this coming weekend with undercoating. I think after i check with the pinion depth tool i'll find out i could use the factory shim
Quick Reply: gone batty with the mods bug
