ive never used n20 before.. so heres my question
is a 75hp shot that noticeable when your driving? (i would assume so because 75 hp is a significant amount)
and how long would you say you can drive and constantly hold the nos button before it runs(at full throttle) an estimate..
I started with the 75 shot and it's pretty noticeable. Without a bottle warmer you're going to loose pressure fairly quickly, the nitrous operates best at 800+ psi so when you dip below that you're not getting all 75hp, with a bottle warmer it lasts much longer since the nitrous is heated when it gets below a certain psi to ensure the proper amount of pressure.
