Speedometer always +2 mph
Old Sep 12, 2008 | 07:19 AM
crazyassracer's Avatar
crazyassracer
Originally Posted by jahudso2
if you have a handheld tuner, check to make sure your axle ratio and revs/mile match your rear end ratio and your tire size
Right. Not the problem. If it were, my odometer would be off. It's dead on. My revs are set at 765/mile which is right according to the tirerack website and my observations with the freeway mile markers. Also, with gear discrepancies your speed wouldnt hold a constant deviation. It should be farther off the faster you go.
I just need that stupid little needle adjusted two ticks to the left.
Old Sep 12, 2008 | 07:36 AM
JD57's Avatar
JD57
I think most speedometers read alittle fast, motorcycles being worse than cars.
My GPS always reads 2 or 3 MPH less than the speedometer.
Old Sep 12, 2008 | 07:44 AM
crazyassracer
I'm sure you're right. It just bugs me. I hate to have to think when I'm driving.
Old Sep 12, 2008 | 08:46 AM
157dB's Avatar
157dB
Cut & Paste Expert
It makes the miles rack up faster than they actually are.
Ford has gotta love that.
Oh yea, they had a hand in the calibration in the first place.
Hmmmm.....
Old Sep 13, 2008 | 11:27 PM
Orion_240's Avatar
Orion_240
Ford (and most manufacturers) make the speedometers very optimistic. I was checking mine against my GPS on a recent trip and when the GPS said 65 my car said 66. At 75 the car said 77. I know the GPS won't show how close it is to the number, like it won't say 65.6 or 65.9, but it is definitely off. My tires were just checked and actually a little overinflated to 35 psi. Stock gears, tires, etc.
I wonder, if it was off by a growing percentage instead of just one or two mph, would increasing the tire size a little fix the error?
Any mathematicians?
Old Sep 14, 2008 | 08:39 AM
Goldenpony's Avatar
Goldenpony
Default SPEEDO
Car speedos aren't all that accurate
Old Sep 14, 2008 | 09:05 AM
timothyrw's Avatar
timothyrw
the odometer is not affected. check the OP, he measured the odometer and said it is right on.
if it wasn't, ford would be looking at a class-action lawsuit. it happened to honda:
http://articles.moneycentral.msn.com...sOdometer.aspx
Hmmmm.....
mtgldr
Feb 3, 2024 09:00 PM
articman
Jun 21, 2018 11:45 PM
bjdutch2005
Mar 24, 2017 03:38 AM
TCStangerv6
Oct 11, 2015 05:57 PM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
