Throttle Body Adapter plate
Old Sep 22, 2008 | 11:40 AM
howarmat's Avatar
howarmat
s197 Junkie
it depends on what the the TB cost is. I thought the JDM kit was 400 and the adapter was only 100. Could be wrong though. I got my kit for 230 used but the plate is special and not all TB plates work.
Old Sep 22, 2008 | 12:00 PM
sevenleaf's Avatar
sevenleaf
The JDM spacer is 200 bucks I did not feel comfortable buying from RPMoutlet from all the troubles I heard about them.
The plastic coupling adapter will not fit the gt500 throttle body. I ended up trying to force my steeda black plastic adapter on and it was such a tight fit I wasn't happy with it.
I needed to drill slots at the screw holes on the throttle body then connect it all together. It was really easy.
140.00 Throttle body
200.00 Spacer
50.00 Coupling
4.00 Clamps
The reason you need a spacer is is the valves on the throttle body will not fully open. They push against the back and or the sides of the intake opening.
you can port your blower opening but you need to remove it to do that and I didn't feel like removing the top of the blower at this time. ( this is on a saleen supercharger )
Old Sep 22, 2008 | 04:08 PM
redfireshaker06's Avatar
redfireshaker06
Well I'm getting the Ford throttle body. I might take my chances w/ RPM outlet because theres comes w/ the bolts, spacer, and hose.
Old Sep 22, 2008 | 05:23 PM
sevenleaf's Avatar
sevenleaf
JDM's comes with all that too but I purchased just the hose alone in hope that I can make the throttle body work without the spacer.
Good luck with RPM outlet
piotrek53
Oct 13, 2015 06:54 PM
JDWalton
Sep 24, 2015 08:47 PM
dudeguy421
Sep 24, 2015 11:16 AM
kachuy10
Sep 22, 2015 01:27 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
