anyone using zex kit??
Old Sep 22, 2008 | 09:19 PM
TOMBSTANG's Avatar
TOMBSTANG
Originally Posted by SURF
Never heard of it, what is it that your talking about buddy?
lol....
Old Sep 23, 2008 | 12:08 AM
q8stang's Avatar
q8stang
yeah
Old Sep 23, 2008 | 12:05 PM
ybnormal's Avatar
ybnormal
Is it just gas that pours out, or do you have a leak on the nitrous side to. I m with the majority here, check to see if you got trash in your gas side sol valve. If it is both gas and nitrous side you have got a problem with that module. I am sure you double checked everything, wiring to your throttle positioner and the input on input side and output on the out put side.
In the normal sytem pressure from yor gas side should be 30 + lbs to the unit (gas) nitrous side whatever is in the bottle. I guess you haven't gotten that far or have you. I didnt try hooking up the nitrous until I got the gas side right. You can try compressed air thru the nitous side to see if that side leaks.
If it does just call zex and have them send you a replacement. Good luck with this and hope it works for you. What kinda shot are you going to be running to start with? what is your upper shot limit? did you get the acessories.?
Old Sep 23, 2008 | 12:45 PM
06elnr's Avatar
06elnr
you dont need any tape or paste, just screw them together.
Old Sep 23, 2008 | 11:28 PM
q8stang's Avatar
q8stang
the gas pours out of the nozzle for 1-2 sec only when i arm it (power on) . and it never seems to work on wot or any time
Old Sep 30, 2008 | 08:16 AM
ybnormal's Avatar
ybnormal
What ever happened? Is your system functional now?
Old Sep 30, 2008 | 10:20 AM
D_Gusler's Avatar
D_Gusler
what size shot you spraying?
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
flash_xx
Oct 16, 2015 07:23 AM
Drastang
Sep 30, 2015 03:48 AM
