Shelby CS-69 Wheels / Larger in rear?s
I think if it was a 19" front and 20" rear that would look good, but the 18 -20 is too big a jump IMO.
I also love the CS 69's in 20's. I think they would look great. Post pics when you get them.
Oh and for tire sizes I would go 255/35/20 front and 295/35/20 rears. Nitto Invo's. Good luck.
Thanks for the input guys! I have to say, I haven't decided to actually go with these sizes, I just wanted to bounce it off some members here. So 20s all the way around? I do want a little wider tire in the rear, that's why I asked about the 10" in the rear and the 9.5" in the front. So I should be good with same size all the way around, high wise, but I can go a little wider in the rear?
Degeze...rims look sick!
My wheels are 9.5" all around and I have no problems or issues with clearance at all. I guess choosing wheel size depends on what look you are going for. If you go with 20s you will probably have to go with a shorter tire, that is the reason I went with 18s. With 18s I was able to get a wide wheels, taller tire (45 series) while having the look I wanted. I have 255/45/18 on my wheels but I could have went with a 275 maybe even 295 on the rear. Hope this helps.
Thanks.
to the OP, go for the 18's
2 cents
Going wider in the rear is fine. I plan on getting 18x10 in the rear and 18x9 in the front. I read somewhere that you really don't want to go wider than 9 in the front.
I want these in chrome: http://www.cruizinconceptswholesale....ts.asp?cat=308
musnicki
09-23-2015 07:11 AM
Dragonus18
09-09-2015 01:21 AM
