spacer plate between engine and transmission
Old Nov 17, 2008 | 04:43 PM
defiance's Avatar
defiance
Default spacer plate between engine and transmission
so after digging in the forums i finally found out that the ~1500rmp vibration is coming from spacer plate between engine and transmission. My car no longer has warranty so i was hoping someone can find some pics of the actual plate and where it is making contact, so i could fix it myself.
Old Nov 17, 2008 | 04:46 PM
Derf00's Avatar
Derf00
Gentleman's Relish
The noise you're talking about is under a TSB, TSB's are not necessarily warranty items. Take to a dealership and ask them about that specific TSB. I don't know the number right off the top of my head but depending on the dealership they may just do it for you.
Old Nov 17, 2008 | 04:50 PM
howarmat's Avatar
howarmat
s197 Junkie
I dont think its the same vibration. It normally occurs around 3K only.
Link to the thread with solution
https://mustangforums.com/forum/2005-2014-mustangs/337453-stupid-metal-rattling-noise-at-3k-rpm-edit-solution-found-9-7-07-a.html
Old Nov 17, 2008 | 04:51 PM
defiance's Avatar
defiance
the dealership i have been going to is very good worked on my car about 3 times trying to find the problem and never charged me anything. I guess ill go back and talk to them again. I wish someone actual had a TSB they could post tho.
Old Nov 17, 2008 | 05:01 PM
defiance's Avatar
defiance
https://mustangforums.com/forum/showthread.php?t=337453
well i dont know the problem is so similar, at 1500rps i get a grinding noise i swear its metal to metal, i can even feel it through my steering wheel and gas pedal. Only does it while in drive, at any speed and any gear....wth
Old Nov 17, 2008 | 11:25 PM
HypromanGT's Avatar
HypromanGT
Does it do it when cold only, or all the time? I know I had a heat shield that was making an awful vibration at about that RPM, but would only do it when the car was cold.
Old Nov 19, 2008 | 11:10 AM
defiance's Avatar
defiance
it does it all the time, i looked under the car for any metal to metal contact and could not find anything.
Old Nov 19, 2008 | 11:47 AM
Texotic's Avatar
Texotic
if it was a heat shield, you wouldn't feel it in the steering wheel and pedal, though...
drfister
May 3, 2018 10:38 PM
Urambo Tauro
Dec 17, 2016 03:30 PM
mtxplod
Aug 29, 2015 01:43 AM
Urambo Tauro
Aug 27, 2015 10:53 AM
inyadreems
Aug 21, 2015 09:10 AM
