I am moving all over this country right now but I finally got to my new duty station so I will be able to climb under the car and see if the exhaust is loose.
Is it a rattle or more of a thunk or a clunk? If you have some other mods then what is listed in your sig like LCAs/UCA 1pc DS, these could also cause noises if not installed properly.
I finally found the problem today once I had a chance to crawl under the rear end and check it out. The right side exhaust pipe is about a 1/4 inch over the axel. The heavy load in my trunck was causing it to hit.
Thanks though. My car is now going in the garage for a little bit.
I finally found the problem today once I had a chance to crawl under the rear end and check it out. The right side exhaust pipe is about a 1/4 inch over the axel. The heavy load in my trunk was causing it to hit.
all we had to do was look at your mods and tell you what it was!
Like a doctor doing a patient analysis, when someone has rear rattles the first thing we need to know is if you've added aftermarket exhaust!
