cold weather = tpms light
Old Jan 16, 2009 | 01:01 PM
shanec's Avatar
shanec
Default cold weather = tpms light
Where's the reset button?
Old Jan 16, 2009 | 01:08 PM
howarmat's Avatar
howarmat
s197 Junkie
You mean for the dash message?
Old Jan 16, 2009 | 01:30 PM
Ato's Avatar
Ato
Cold temps = denser air = lower air volume. AKA, add air to your tires and the light will go away.
Old Jan 16, 2009 | 01:37 PM
Norm Peterson's Avatar
Norm Peterson
It also might be worth seeing what the owner's manual has to say about it. The TPMS lamp is also used to indicate faults in the TPMS system, and I think the lamp behaves differently if that's the case.
If you mean the IUP display, just hit the IUP's 'RESET' button to reset the IUP. The TPMS dash lamp will remain lit, though.
You may also have to either let it sit overnight or drive it a few miles to reset.
Norm
Old Jan 16, 2009 | 02:40 PM
avengence's Avatar
avengence
Also your tire pressure goes up as the tires get hotter, just FYI. I run mine at 37 or so and they get up to like 42 when I drive.
Old Jan 16, 2009 | 03:06 PM
Devil Wolf's Avatar
Devil Wolf
dont forget the spare! ive been burned on my spare being flat before and wondering why the damn light wouldnt shut off.
Old Jan 16, 2009 | 09:47 PM
shanec's Avatar
shanec
Turns out I'm at 25 psi all the way around. Filled them up to 32 psi tonight. Haven't checked tpms yet.
Old Jan 17, 2009 | 12:05 PM
157dB's Avatar
157dB
Cut & Paste Expert
The reset buttons, there are four of them, are mounted
on the rims themselves. You reset them by putting air
into the reset button until the pressure reaches the
OEM recommended pressure posted on the drivers
side door jamb.
Or you could just read the Owners Manual.
Thats an old wives tale.
There is not a TPMS sensor in the spare.
MusicCity615
Sep 12, 2015 07:05 AM
Blk Vert
Sep 9, 2015 12:16 PM
amandahchase
Sep 3, 2015 10:09 AM
cbird1177711
Sep 2, 2015 04:12 PM
