Taillight Bulb out... I think...
I have the webelectric sequentials and the other night my left blinker started clicking really fast so I knew that something was out. I looked at the front and it was working just fine but on the rear left side for maybe the first 2 clicks the 2 outermost bulbs would sequence as usual but the innermost one would not light up and after the first 2-3 clicks it stopped blinking all together and it did it multiple times so it seems like one of the bulbs is just out so basically just need to know where I can get a new one? Do I just go to the dealer and ask? Will they have it in stock?
yeah anywere will have em. To remove just open the trunk and pull back the carpet stuff and its 3 nuts.. Use a deep (11 mm or there abouts) and then give the studs a little push and the housing will pop out. Pull the housing away from the back of the car and rotate the plastic grey housing out counterclockwise and just pull the bulb straight out. put the asselbly back together (half assed) and then go to get your new bulb.. just do it in the parking lot.. HA and then bring the bulb in to get the exact bulb. I think its not neccisarly the same as stock as all 3 are 2 stage bulbs. Anyways reinstall the bulb and put back together.. Shouldnt take more then 10 minutes to take out.
Find the right sized socket and just do it in the parking lot.
When you pull the assembly from the car just be carefull not to stress the wires. there is a little plug thingy that takes up slack from the wires, slide that off to give you extra room to work. just dont let the assembly dangle from the wires or tug on it and all should be just fine!
andrew1969
16
01-08-2016 02:48 PM
lincolnshibuya
12-08-2015 04:37 PM
