Help! Header stud stuck!
Old Apr 8, 2009 | 11:22 AM
Riptide's Avatar
Riptide
How do those cam style stud removers work anyway? For us not so mechanically inclined people an explanation would be nice. I'm assuming you put the stud through the empty hole and then do something to apply pressure on it with that device. Then you can move the entire device and unscrew the thing.
Old Apr 8, 2009 | 02:24 PM
jahudso2's Avatar
jahudso2
Yeah I was so relieved when they finally came loose. I will try to get some videos tomorrow and I will do some runs with my accelerometer next week so I can compare it with the data I got from before I installed them. The sound didnt change much at idle, but at high load/ high rpms, it's much louder. I think I might need an OR-H next
Old Apr 8, 2009 | 04:08 PM
MadMike1337's Avatar
MadMike1337
nice man i just ordered the JBA headers and magnaflow catted X its enroute to my house!!!!!!!! cnat wait. how does the power feel
Old Apr 8, 2009 | 10:27 PM
jahudso2's Avatar
jahudso2
I forgot to reload the tune at first and the power felt greater, but not really impressive. Then I reloaded my brenspeed 93 octane tune and now this thing pulls like crazy. I can break the tires loose much more easily now and if I modulate the throttle, this thing takes off like a rocket. In my butt dyno, this mod gave me much more power than the intake/tune or change from 3.31s to 3.73s.
Old Apr 9, 2009 | 10:30 AM
Riptide's Avatar
Riptide
Reloading the tune always results in a perceived boost in power. I'm not sure what it is exactly but some learning tables get reset when you put the tune back on and it makes the car feel a little bit snappier. After you drive it for a while the car learns again and this difference goes away.
Old Apr 9, 2009 | 10:38 AM
jahudso2's Avatar
jahudso2
I had just reloaded the tune 2 days before I reinstalled the headers and took my accelerometer runs right after reloading each tune. I still felt a massive increase in power, and the wheels are breaking loose like crazy now. The gains I am feeling are due to the headers, not the reloading of the tune.
Old Apr 9, 2009 | 10:40 AM
Riptide's Avatar
Riptide
I didn't mean to make it sound like you wouldn't feel any boost from upgrading the headers. Just explaining that reloading the tune in and of itself results in a perceived boost in power. Your post that I responded to made it seem like you didn't notice anything until you reloaded the tune. Hence why I responded with that.
Old Apr 9, 2009 | 10:50 AM
Norm Peterson's Avatar
Norm Peterson
When you turn the wrench to remove the bad fastener, the torque that you apply drives an eccentric "wheel" inside the tool to grip the bad fastener even tighter. The harder you twist, the tighter it grips. Sort of like "Chinese finger traps" except this thing works with rotation instead of a straight pull.
But you still have to be a little careful and have a little "feel" for this - it might be possible to break the fastener that you're trying to get out.
Norm
Old Apr 9, 2009 | 11:09 AM
svastano's Avatar
svastano
I know it is too late but for someone else it might help! If you have a stud that is stuck. Get a torch and heat the head near the stud but not the stud. Then when it is real warm get an old candle and put it near the stud and the block and the wax will suck into the threads . It will back out smooth as silk!
Old Apr 9, 2009 | 11:12 AM
Riptide's Avatar
Riptide
Norm thanks for the explanation. I know that a friend of mine had an exhaust header bolt which didn't want to come out on his WRX. Eventually we got it off of there by screwing a couple nuts down onto the thing and then heating it with the torch. PB blaster was also involved. It did eventually come out.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
junior04
Sep 28, 2015 10:53 AM
jstrothe
Sep 24, 2015 12:17 PM
rafotree
Sep 22, 2015 03:55 PM
