removing the wheel locks...
Old Apr 17, 2009 | 02:55 PM
  #21
wingman75's Avatar
wingman75
Just patch it yourself. Follow this guide in the link below.
http://www.ehow.com/how_2175716_patch-flat-tire.html
Old Apr 17, 2009 | 02:57 PM
  #22
wingman75's Avatar
wingman75
double post
Old Apr 17, 2009 | 10:10 PM
  #23
gtguyonli's Avatar
gtguyonli
Put some air in the tire and go to a tire store, I'm sure they can plug it without removing the wheel.
Old Apr 17, 2009 | 10:24 PM
  #24
algregory's Avatar
algregory
FWIW,
I had to put the spare on my car, '05 GT, and i used the lug nuts along with the locking one. Of course I put the on good and tight. It was only about 30 miles, probably less back to my house. Ended up getting new tires all around. When they went to remove that wheel the top of the locking was GONE! I later found it in my garage close to where the car was parked, but far enough away that the sucker must have POPPED off somehow maybe due to temp changes or something.
Old Apr 17, 2009 | 11:41 PM
  #25
light speed's Avatar
light speed
ok i found the wheel lock key in my glove compartment and got the tire patched.
thanks for the help guys, a lot of good tips are in this thread.
Old Apr 18, 2009 | 10:01 AM
  #26
157dB's Avatar
157dB
Cut & Paste Expert
Originally Posted by light speed
would putting [color-red]fix-a-flat[/color] into the tire, then driving to a gas station, fill up with more air, then drive to nearby tire place be an option?
i have the tire pressure monitor and im sure itll be damaged from the fix-a-flat but idk what else to do
Fix-A-Flat will make the inside of the tire unpatchable.
Been there, changed a few thousand tires, done that.
It turns the inside of the tire to a goo that a patch
wont stick to no matter what you do.
Ford needs to make the glovebox smaller so things
dont go into limbo when placed in it or a dedicated
place for the ever so important OEM wheel lock key.....
Old Apr 18, 2009 | 10:39 AM
  #27
Nuke's Avatar
Nuke
And you didn't look there to begin with? That's grounds for losing some man-points...
Old Apr 18, 2009 | 12:38 PM
  #28
Art161's Avatar
Art161
Have you had any experience with a "green" product called Slime? Supposedly it cleans up okay, and doesn't damage the TPMS sensor.
Tivo304
Aug 28, 2023 12:19 PM
mmarsh3014
Wheels & Tires
Oct 20, 2015 09:08 AM
wawagner82
Sep 13, 2015 09:02 AM
Sep 10, 2015 08:39 PM
