CONVERTIBLE Discussions....
Old Jun 21, 2005 | 01:02 PM
Professor Wizard's Avatar
Professor Wizard
MF Moderator
Default CONVERTIBLE Discussions....
Since I own a 05' GT Convertible I thought I might start up this thread to discuss issues, questions and concerns about our convertibles.
I've owned several Converts over time, so I have a little experience with these.
I got a little "surprise" last night… so you convertible owners take heed.
FINALLY decided to put my Convertible top up!... (Considering, since I hadn't done it yet, I didn't even know if it worked at all.)
Now - - - Keep in mind, the dealership put the top down when the car arrived on June 2nd. IT sat in their show room until I went to pick it up and I left the top down all the time I had it up until last night!
So the top sat folded up with the boot on for 20 days!
On the first attempt it stopped like 2" short of reaching the windshield... I thought "CRAP - This thing doesn't work!) But - I don't give up easily... SO.... I raised and lowered it a couple of times and each time it did it stretched a little closer to the windshield - Eventually I was able to wrestle it into its mountings on the windshield.
Put it down this morning on the way to work... When got to work I put it up... Came right up and stopped with the lead pins JUST holding over the mounting brackets. No problem.
So - If you have a convertible and haven't put the top UP in a while... Don't worry... it is not broke, it just shrunk and you have to exercise it a little to get it to lock in place. I suppose it is also a preemptive warning to be careful raising it in cool weather as the material might shrink enough to prevent you from latching it – at least not easily.
Also - for those of you that have never had a Convertible - the book says never to put it down while wet. THEY MEAN IT!
Putting your top down wet causes mildew to grow on the vinyl. That folded up wet top sitting in the sun raises the humidity in the boot compartment to astronomical levels and creates the perfect environment for those little mildew boogers to grow like MAD!
Although everyone believes vinyl is mildew resistant - it is NOT impervious to the stuff. Mildew will eat away at the vinyl and cause it to flake, become brittle and make it weak. This will result in a horrible looking top that tears easily and will have cracks in the folded places. NOT to mention the SMELL, which you can never really quite get rid of.
Last thing. Your top is pretty easy to take care of. Keep it clean but never use any harsh solvents on it – those leather cleaner products are great to use. Pick up some type of rub in waterproof or top conditioner, and rub your top down at the start of summer and winter and it will last you for years.
For the record – my top takes 16 seconds to raise or lower.
_____________________________
Old Jun 21, 2005 | 02:01 PM
Robs05gtvert's Avatar
Robs05gtvert
Default RE: CONVERTIBLE Discussions....
ORIGINAL: Professor Wizard
since my CAI/Predator install...my top takes 14.9 seconds to raise or lower....
Old Jun 21, 2005 | 02:14 PM
Mister Roper's Avatar
Mister Roper
I need someone to time me. Another trick I use: I go through the local touchless car wash but when I get to the dryer I park my hood under it and wait for the timer to run out. Then drive it three blocks home and finish her off.
Old Jun 21, 2005 | 02:21 PM
ChewbaccaD's Avatar
ChewbaccaD
I come from owning a jeep... electric tops are awesome!
Old Jun 21, 2005 | 02:29 PM
Horst's Avatar
Horst
I had problems puting my top for about four times. Now it works great, but I alway close it at night. My neighbor's cats seem to like to spend the night in my garage.
[IMG]local://upfiles/14754/18E45D1F44F4438FADD3C88370F57DFF.jpg[/IMG]
Old Jun 21, 2005 | 02:30 PM
Herknav's Avatar
Herknav
time to shoot the cat...
hmm.. your car seems familiar...
Old Jun 21, 2005 | 02:34 PM
Robs05gtvert
I had my car 2 days and the left clip broke on my top. I called the dealer and told them about it and he said I was waiting for your to call. They have not had one vert yet that didn't have the clip break...so be careful. He said it is a defective design. Anyone else have that problem?
Old Jun 21, 2005 | 02:58 PM
ChewbaccaD's Avatar
ChewbaccaD
Rob, I haven't had that problem. I've only had her for a few days now, but I've put the top up-and-down a lot. It still feels sturdy. Wonder how old that design flaw is? I've got a 5/05 build. Thanks for the heads up.
Old Jun 21, 2005 | 03:59 PM
huffhuff's Avatar
huffhuff
lubricating the hinge points will help too.
Old Jun 21, 2005 | 06:09 PM
Exilenla's Avatar
Exilenla
Nice Ride.....or is that a picture of mine you copied from the gallery
ORIGINAL: Herknav
