whits end with Pypes MM
Old May 2, 2009 | 09:17 PM
  #21
one eyed willy's Avatar
one eyed willy
Originally Posted by Rubrignitz
Oh ****, don't jack the car and have someone throttle it! I know ***** knows what he's doing but damn... I would never attempt that.
Just make sure you have about 1'' of space between your hangers and brackets. If you bend the hangers it shouldn't be difficult to get 1'' clearance. In my case I had about 1/4'' clearance when cold and when hot the hanger would make contact. So a good 3/4''-1'' clearance when cold is minimum.
They acutally cut my hangers and re-welded them back onto the pipe. A good exhaust shop should be able to do this easily.
it was on stands,no way it would have fallen.
Old May 2, 2009 | 09:25 PM
  #22
Rubrignitz's Avatar
Rubrignitz
You're right, but it just makes the hair stand up on the back of my neck.
Old May 2, 2009 | 10:29 PM
  #23
TOMBSTANG's Avatar
TOMBSTANG
lol ^^^^^ ya that is crazy I see myself doing that with my gf and her some how making the car fall off of tstands and ends up driving over me and through the wall into the neighbors living room
Old May 2, 2009 | 11:09 PM
  #24
one eyed willy
you bunch of sissies!
when you brining the car over mike?
Old Aug 22, 2009 | 07:22 AM
  #25
luckey13's Avatar
luckey13
"The cricket noise is your exhaust hanger rubbing the hanger bracket. I fixed this by removing the bracket from the frame and grinding off where it rubbed, but any exhaust shop should be able to reposition the brackets so they don't make contact.
They look fine when under the car, but they will move under load and when hot. I believe it was the passenger side hanger for the over the axle pipe, not the rear most hanger.
You should be able to see a spot where it's rubbing."
__________________
MOOSE, THANK YOU so much for solving my squeaking issue!!! I have been trying to pinpoint this for weeks and going nuts! Only to find this post and this was exactly my remedy! Just bent it bak a bit and just grinded down the bracket a bit with the dremel! YES, NO MORE NOISES!!!! I am cured!
flash_xx
Oct 16, 2015 07:23 AM
kevsgt
Oct 9, 2015 10:12 PM
88 orangepeel notch
Oct 5, 2015 09:03 AM
UrS4
Sep 30, 2015 10:13 AM
marc954
Sep 29, 2015 11:18 AM
