Buying new mods....just need everyones input!!
Old May 3, 2009 | 08:53 AM
S197GT07's Avatar
S197GT07
I'm assuming the clutch was like $799, or $899. because if its $99 I'd jump on that in an instant.
Old May 3, 2009 | 09:00 AM
siberian.mist's Avatar
siberian.mist
-rod ends will be berry loud id go with poly bushings on the control arms, should be a little cheaper too.
-my car is my daily driver for 3 seasons, i have dspecs, they are a million times better and can be more comfortable than the stock shocks/struts..
Old May 3, 2009 | 12:53 PM
aloredo07's Avatar
aloredo07
i'm sorry yeah the clutch is $899. i heard a lot of good thing about the d specs on this forum.
Old May 3, 2009 | 01:11 PM
2007CalSpec's Avatar
2007CalSpec
Originally Posted by Legion5
Why are you buying a front sway bar when you just made your car handle worse than a decapitated duck with some of the other stuff?
Also you'd need about a thousand horsepower to make use of most of this setup, Is that what you're after?
It makes no sense to start lowering your car either as that will just be counterproductive, but I'll agree to go with the 3.5" shaft.
Hope that helps.
I thought the same thing about the front sway bar choice. I read somewhere that our Mustangs don't really need an aftermarket front sway bar since the stock one is pretty good. Buying a new front sway bar would be a waste of money. What our stangs really need is a beefier rear sway bar to correct the understeer our stangs tend to have. That's what I'm getting when I have the money.
Old May 3, 2009 | 02:52 PM
aloredo07's Avatar
aloredo07
thanks i will reconsider the front swaybar. i got the money but i am in no rush to buy right away. i wanna be completely sure thats waht i want. thanks everyone for your help.
Old May 3, 2009 | 03:46 PM
rdsx18's Avatar
rdsx18
Be sure you don't mind road noise, I hear that rod ends are very loud.
Old May 3, 2009 | 04:31 PM
Legion5's Avatar
Legion5
Originally Posted by aloredo07
The anti roll bar keeps it from having body roll when you are turning corners or sharp curves on the highway. As far as the front sway bar i just thought if i was gonna do the rear suspension might as well do the front one. Yeah i think a set of pulleys sound good.
What are you talking about? I didn't make the front sway bar comment because the front sway bar in the Mustang is adequate I made the comment because with that list of mods you've turned your car into an all out drag machine.Your car will become impossible to bear driving on the street for an average person that expects to ride comfortably or to take a corner a very high speed. The anti roll bar has nothing to do with cornering. It's designed to prevent this:
Notice the roll on the rear axle (not talking about the body)?
It's obvious from the anti-roll bar's design that it isn't designed to be cornering.
Old May 3, 2009 | 05:24 PM
aloredo07's Avatar
aloredo07
maybe i was confusing the anti roll bar with the rear sway bar. i'll check it out again to make sure i have the right one
Tivo304
Aug 28, 2023 12:19 PM
5.0muscle
Jan 11, 2016 01:17 PM
04stangman
Sep 17, 2015 01:45 PM
Sep 8, 2015 11:50 AM
