how bad is power shifting...
"Feathering" the clutch is nothing more than allowing it to slip. It's probably impossible to avoid this happening at least a tiny bit with a street or street/strip clutch whose disc has a marcel, but this method should not be deliberately and consciously used once you've got the car rolling. It does create extra heat and wear from the sliding friction.
About the only way I can put it is that once you to learn to match the revs and get your timing down, you can get clean upshifts without causing a lot of impact loading. The marcel and the springs in streetable clutch discs will reduce the severity of the impact somewhat (that's what they're supposed to do), but these can be "bottommed out" on a harsh shift, which sends the impact way up again. Yes, relatively "softer" clutch engagement will cost you slightly in a drag race.
Powershifting does more than speed up the shift time. It converts the rotational momentum of the flywheel/pressure plate/balancer/crankshaft into a very brief torque "spike". For a tenth of a second or three as the engine rpm drops from 6000 (or whatever) down to 4000-ish, you may be getting 400+ ft-lbs going into the transmission from an engine that only puts out 300. After that, it's back to 300 (or whatever).
Norm
Norm
Normally when i launch i drop the clutch and then gas it. Ive never launched while holding the car over 2k. I never break loose and always have bad lag, but soon as its rolling it takes off with out traction loss. And i would think it would be the best method as far as clutch wear because its already engaged by the time it gets the full gas
OK.
That's about 100 fatigue cycles on the 2nd gear synchros and 3rd/4th synchro rings, 50 on the 3/4 hub . . . doesn't suggest that any huge strides have been made in the last 40 years as far as OE regular production durability goes . . .
Speed costs money, or something like that.
Norm
Norm
i've done probably 200 ***** to the wall 1-2 shifts (LIFTING OFF THROTTLE, but very briefly)........here's what it sounds like: http://www.youtube.com/watch?v=4f4lva3SP1Q
(don't mind the slow 2-3 shift =/ )
but yea, AmericanSpeed what were your symptoms of crapped out synchros?? describe in detail plz? i'm worried about mine.
POWERSHIFTING on a TR-3650 will result in TOASTED SYNCHROS if done repeatedly. don't do it. you don't need to.
BTW AmericanSpeed i managed a 12.883 @ 106.58 with just a cai/tune.........and drag radials haha
Once the throttle hit the floor on my run after luanch, it stayed there. I also only pressed the clutch in just enough to slam into the next gear. Never had to shift to 4th with the 3.55 gears, had the rev limitor set to 6900 and would cross just before hitting it.
I knew my synchro was gone because I couldn't shift into 3rd gear, LOL. It would just grind like crazy and not go into gear, so I just drove it home and then to the shop shifting from 2nd to 4th.
DreadPirateRoberts
Sep 26, 2015 02:11 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
