disable tpms light?
Old May 22, 2009 | 06:56 AM
str8wick3d's Avatar
str8wick3d
bump,
Old May 22, 2009 | 09:23 AM
d4rb's Avatar
d4rb
Not sure if this applies in your case, but I know that when people switched clusters for the MyColor ones, they had to go to the dealer and get the "as-built" data updated with a programmer. This might be the case for you as well. Call your dealer and ask.
Old May 22, 2009 | 09:34 AM
157dB's Avatar
157dB
Cut & Paste Expert
Get the cluster 'module' configured with the as built data from
your old cluster. Thats a dealer thing.
The cluster is vehicle dependent and just getting one and installing
it without configuring the 'module', all sorts of DTC can be set.
http://iihs.net/fsm/?dir=344&viewfil...nt Cluster.pdf
http://iihs.net/fsm/?dir=403&viewfil...figuration.pdf
You have more problems than the TPMS light but thats and indicator to the problems.
If the cluster was properly configured, you would not see the TPMS light.
The 07 is looking for TPMS data from the SJB and your 05 does not have that.
Its a problem thats just the tip of the iceburg.
Get your 05s as-built data downloaded to the 07 cluster and all will be well......
Old May 22, 2009 | 01:51 PM
str8wick3d's Avatar
str8wick3d
thanks so much guys.
Old Jun 30, 2009 | 07:31 PM
jtstakelin's Avatar
jtstakelin
Will a SCT or Diablo tuner have a preameter to remove the TPMS?
Old Jul 1, 2009 | 01:39 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
I removed a few posts in response to a post that was reported to me via PM......thanks for the heads up and carry on gent!
Old Jul 1, 2009 | 07:57 AM
157dB's Avatar
157dB
Cut & Paste Expert
No, it wont, sorry to say.
Govt mandated non user-modifiable system.
jwog666
Dec 27, 2021 08:09 PM
4cylinderplus2
Oct 9, 2020 07:45 PM
lincolnshibuya
Dec 8, 2015 04:37 PM
Explosive
Oct 2, 2015 07:45 AM
ChampInSD
Oct 2, 2015 04:55 AM
