quite a predicament again
The 05 is pretty much new and has everything but it is almost a year older than the 06 but has less than half the miles so my wuestion is should I go 06 because it is newer but doesnt have the mpg option thing with the buttons or that shiny dash or should i go 05 which is loaded but might have TSB issues and is technically older than the 06 when they are basically in new condition
well, if age is a concern, check the build date (it's located somewhere on the door sill i believe); the 05 potentially could have been built right at the end of the 05 model run, and the 06 could have been built at the beginning of the 06 model run. so, it may only be a month or two older than the 06.
as far as the options and tsb's go; that part is up to you... i have an 05 and only had to do one or two tsb's (and they weren't really anything too major), and while having things like the 'miles to empty' is nice, it isn't really necessary... i hate to potentially confuse you more by saying that
all in all, just go with your gut
