Throttle position max?
Old May 29, 2009 | 07:02 AM
Norm Peterson's Avatar
Norm Peterson
IIRC, the quadrajet secondaries had throttle plates that would open fully if you put the pedal on the mat, but also had an air valve above the secondary venturies only opened as far as the airflow required. I think you could tune the air valve opening rates. A little like Holley vacuum-secondary carbs, actually.
A Holley double-pumper will stand all four throttle plates straight up at WOT regardless of engine rpm or load.
I also think the reset procedure mentions a specific number of seconds (for some reason, 5 seconds comes to mind). Counting "1000-1", etc., probably gets you close, but isn't the actual spec, so if you tend to count fast it might not "take".
Norm
Old May 29, 2009 | 07:38 AM
ziperhead's Avatar
ziperhead
I suspected Norm would remember about the quadrajet. If you caped the vacuum line it would allow instant opening. At least it did on my 68 GTO
Old May 29, 2009 | 09:22 AM
VistaGT's Avatar
VistaGT
the stock ford tune doesnt allow the tb to open quickly at wot(safety feature to protect against drivetrain shock) the aftermarket tunes disengage this
Old May 29, 2009 | 12:52 PM
moosestang's Avatar
moosestang
I get the same 77% with my aeroforce gauge, it never goes above that.
Old May 29, 2009 | 02:06 PM
NuclearMuscle523's Avatar
NuclearMuscle523
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
That is depressing.
Old May 29, 2009 | 02:09 PM
SirKnightTG's Avatar
SirKnightTG
The AeroForce gauges will show both throttle position and pedal position.
I usually have pedal position selected and it does show 0 to 100. When I would watch throttle position, I would see the same thing as the OP from what I remember.
I like watching the pedal position reading as it's interesting to see how different the car reacts depending on various positions.
Old May 29, 2009 | 02:10 PM
NuclearMuscle523
What is this magical aeroforce thing that reads everything?
lincolnshibuya
Dec 8, 2015 04:37 PM
UrS4
Oct 3, 2015 06:23 AM
guitarman376
Sep 30, 2015 05:54 PM
TfcCDR
Sep 14, 2015 12:08 PM
Sep 8, 2015 11:50 AM
