Goodridge Brake Line Help Needed ASAP
I am installing the rear brake lines, but don't see where to attach the bracket that is in the middle of the line. Does it attach to the "C" clamp that goes around the axle? If I attach it there, the line is rubbing on the parking brake cable. Anybody have any pics?
Thanks
Thanks
They are routed like the stockers you removed.
Rewind the memory function to the recall position.
Try the instructions that came with the lines?
eMail Goodridge (the designer and manufacturer)
for an answer.
for an answer.
I found out what I was doing wrong. Do Not install the front brake line on the rear brake caliper. It will fit, but it will be to long. I feel like a Dumb A$$. The little bracket lines up with the lower c clamp bolt though. Goodridge does not include instructions with their kits. Did I say I feel like an idiot??
Later
Later
bond007
08-26-2015 11:36 PM
jpplaw
08-22-2015 09:29 PM
Fast-Hands
08-19-2015 06:54 AM
