Paint Problems....what do i do?
Old Jul 19, 2009 | 11:12 PM
boomer123's Avatar
boomer123
Default Paint Problems....what do i do?
So I got my front bumper repaint about 2 months ago, and they guys said they paint urethane all the time and they know what to do, and i even explained they have to clean it properly with grease remover to get the oils off from the mold. But now the paint is LIFTING in some corners and it has flaked off and im pretty pissed. It looks like ****, are they responsible for this? can i get them to repaint it or am i **** outa luck?
Old Jul 19, 2009 | 11:18 PM
tranceaddict's Avatar
tranceaddict
if they warrantied their work then yes they are absolutely responsible.
Old Jul 19, 2009 | 11:36 PM
eddypython's Avatar
eddypython
after 2 months they should still fix it. I had my hood repainted after just about the same time. I had some runs in the clear and some primer showing.
Old Jul 20, 2009 | 06:16 PM
pascal's Avatar
pascal
S197 Section Modder-ator
Yep, bad prep. I'm not surprised either.
Cervini's urethane material is a motherfugger to prep and it's pitted...
They have to redo it, but how many tries will it take?
Old Jul 20, 2009 | 09:21 PM
o0xerog0o's Avatar
o0xerog0o
Yes they should be held responsible for the poor paint/prep quality, and really, the only real way to correctly redo the job is to completely strip the bumper back down to urethane, and prime/sand/paint it... I've had to deal with raw plastic bumper repaints that were prepped wrong by another body shop, and they're never a pretty sight. Good luck with it!
Old Jul 20, 2009 | 09:33 PM
eddypython's Avatar
eddypython
adhesion promoter is such a beautiful thing too
Old Jul 20, 2009 | 10:02 PM
o0xerog0o's Avatar
o0xerog0o
Our method for prepping a raw plastic bumper is to wash it, dry it, prep it with a plastic prep cleaner twice to remove all oils from the mold, use a regular prep cleaner, blow it off, spray a plastics adhesion promoter, seal, paint, clear... If done right, that should be it, and the customer won't have any issues. One thing we found out in our area, most shops are skipping out on the plastics adhesion promoter to save that little bit of money, as well as not putting in the flex additive which should be used in the sealer and clear coat.
Old Jul 21, 2009 | 04:32 AM
mygt500's Avatar
mygt500
Multi-Tasking Moderator!
I agree 100% and it looks like my paint and body guy skipped no steps!....3 yrs and no flaking, cracking, etc!
Sorryto read this OP they should cover the fix!
Old Jul 21, 2009 | 06:44 AM
05 Mustang's Avatar
05 Mustang
they should stand behind their work and as everyone else has said, fix it
guitarman376
Oct 11, 2015 01:47 AM
Oct 1, 2015 09:29 AM
mungodrums
Sep 28, 2015 10:54 PM
GLOCKer
Sep 28, 2015 07:36 AM
mustangchef
Sep 4, 2015 08:08 PM
