Crap... Jacked in the wrong spot
Old Jul 31, 2009 | 09:45 AM
  #41
157dB's Avatar
157dB
Cut & Paste Expert
Got a 4 point hydraulic floor lift for the garage and
dont worry bout pumpkin jackin no moe.
Old Jul 31, 2009 | 10:11 AM
  #42
antipeterleague's Avatar
antipeterleague
lucky bastard
Old Jul 31, 2009 | 01:14 PM
  #43
06elnr's Avatar
06elnr
i jack my pumpkin as often as possible...
Old Jul 31, 2009 | 01:28 PM
  #44
antipeterleague
more than once a day?
Old Jul 31, 2009 | 01:53 PM
  #45
Derf00's Avatar
Derf00
Gentleman's Relish
The advice in this thread Fails hard.
To the op, although it's most likely there was no additional damage done, your inexperience (the fact you would put the jack in such a place and not already know where a Jack SHOULD go) tells me you should go to a service center or repair shop to have things double checked and even had your car towed to have it inspected. Period.
Internet diagnosing can be hard enough for an experienced person but can be near impossible for an inexperienced one. You could be leaving out vital information or worse, overlook a detail because you didn't know to look for it and therefore didn't convey it to us.
Next time, have someone with more experience to help you so you can avoid simple mistake that could cause serious problems and learn the correct way to do things. Fuel + Spark = fire. Brake pads + Fluid = no brakes, therefore, when working on anything related to these systems, if you don't know what you're doing, have someone help you so you can learn the proper way to work on them. Otherwise you put yourself and potentially others at risk.
Old Jul 31, 2009 | 02:04 PM
  #46
jz's Avatar
jz
I forgot about this post. Still one of the funniest things I've read. I'll read it again, all the sarcasm makes you fall off of your seat.
Old Jul 31, 2009 | 03:50 PM
  #47
06elnr's Avatar
06elnr
sometimes! This sounds like a RTFM problem to me...
Old Jul 31, 2009 | 04:36 PM
  #48
one eyed willy's Avatar
one eyed willy
i use red loc-tie on my valve stem caps,works like a champ!
Old Jul 31, 2009 | 04:41 PM
  #49
Mishri's Avatar
Mishri
Mish-ogynist
hahahaha.. ahh man i i never saw that thread.. hilarious..
Old Jul 31, 2009 | 05:11 PM
  #50
Bmr4life's Avatar
Bmr4life
10 minute fix. 30 mins if its your first time.
Dokilar
15
Oct 16, 2015 08:13 PM
ChampInSD
Oct 2, 2015 04:55 AM
marc954
Sep 29, 2015 11:18 AM
popsotto
Sep 28, 2015 06:58 AM
