Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
- Ford Mustang 2005-2014: How to Change Cabin Air Filter
Step by step instructions for do-it-yourself repairs.
Cabin air filter
Mine is pretty filthy. I'm going to call around today and see if any of the other auto parts stores have them in stock. I can't believe the dealers don't have them. Does noone bring their mustang in for a 15k service? So stupid.
Personally, I'd say no. I have 31k miles and haven't changed mine yet even though I've had a replacement on-hand for the last 20k miles. It's just not on my priority list since it's not a performance or visual issue. I've never heard of anyone's AC not working because their filter was blocked. I'll get around to it...
Don't get yourself in a tizzy about it.
Are you fooling ME? Going to the stealership for filters and such?
Any local parts store worth a grain of salt will have the cabin air filter.
I got mine from moss muscle and it was a micron aire with the detailed
vehicle specific instructions...
Check your cowl clips while you are in there....
if you live in an area with fall leaf drop its a good idea to
check the drain in the well area below filter because some
people have had problems with it plugging up and causing
water to come in thru lower vents during heavy rain.
Is the bottom of the well easily accessible? Or do you need a vacuum with a crevice tool to get to it? I've heard that that drain clogging is a contributor to the water leak issue.
