Flex plate issue?
Old Dec 1, 2009 | 11:09 PM
2007CalSpec's Avatar
2007CalSpec
Originally Posted by charliebrown266
Its not the flex plate that is the problem,it's the plate that goes between the motor and trans, take like ten mins. if you look at the bottom of the trans you well see the plate and 2 bolts you have to remove.
Cool! Thanks for the info.
Old Dec 2, 2009 | 01:19 PM
ffk_pennywise's Avatar
ffk_pennywise
I had my car on a lift today at the tire shop having my winter wheels mounted back up. Me and the tech took the aforementioned 2 bolts out and shimmed the plate with a thin washer. Problem solved. I cannot even begin to tell you guys how happy I am about this. You dont realize how bad that rattle is until you fix it!
Old Dec 2, 2009 | 01:41 PM
2007CalSpec
You didn't use a rubber washer? Just wondering since I have plenty of various sized metal washers in my garage but no rubber ones.
Old Dec 2, 2009 | 02:09 PM
ffk_pennywise
We just used some washers the tech had lying around. I was in the shop for tires and the conversation about the rattle just came up. Took maybe 5 minutes. Only took that long because he had to look for washers. Pulled the 2 lower bolts out. I grabbed the plate and bent it out a bit to make room for the washers. Then reinstalled the hardware.
Now if I could figure out how to fix the air leak in my drivers side window I'd have a quiet car.
Old Dec 4, 2009 | 05:35 PM
gschrono's Avatar
gschrono
I had the same problem on my 08 gt on a cold start it would be very loud. just got it back from ford today ( it took them 3 days to fix do to problems getting the part and also my tranny was frozen on the dowel pins) turns out mine was also the the plate that goes between the motor and trans. the old one is a solid plate but on the new one they have re designed it so it has a hole cut out in the middle of it don"t really know why.
but no more noise! id say if you have the warranty def take it in if you cant stand it they told me it was a known problem
mtgldr
Feb 3, 2024 09:00 PM
guitarman376
Oct 11, 2015 01:47 AM
accarter
Sep 21, 2015 11:56 PM
maestro1024
Sep 21, 2015 02:40 PM
ccdguy
Sep 19, 2015 05:20 PM
