I just bought one off ebay. Just make sure it's the right code and frequency. It's super easy to do. Don't go to the stealership. They will laugh at you for 55 min and do the work in 5.
Screw the code and frequency.
The freqs are all the same (420MHz as mandated by the FCC)
and the 'code' is recognized then programmed into the PCM
when you 'program' it like the owners manual says to.
Its the FCC ID # is what you are trying to match.
