Last edit by: IB Advertising
Browse all: Ford Mustang Interior Guides
- Ford Mustang V6 2005-2014: How to Remove Door Panels
Step by step instructions for do-it-yourself repairs.
How to REMOVE door panel..??
Im looking for help on this, my drivers side windows is screcthing and popping and when i rollin down and up, so much that the wife comminted on it. Any one have a write up or how to on getting the Drivers side door panel off..?? Thanks
-SGT McCauley
-SGT McCauley
https://mustangforums.com/forum/4-0l...or-panels.html
Take it to the stealership if this dont help.
157 DB Thanks for being a douch bag ! A simple answer would have done fine ! I finally figured it out though ! Thanks to everyone else who helped ! (and using search function from the iphone is nearly impossible FYI)
I did this exact process 1 week ago
- pull off the mirror panel first and disconnect the power mirror cable
- pull off the panel behind the door release lever (remove the torx screw behind)
- behind the armrest handle their is a panel that pulls out as well, remove this panel and the screw behind it
- remove the window button assembly and there is one final screw under that
- once the 3 interior screws/bolts have been removed all you need to do is unscrew all the bolts around the perimeter of the door
- As you pull the entire door panel off disconnect the various electrical cables inside
...and you are done. Except for the door release cable, I never could figure out how to unhook it so i always worked on my door with the panel still connected by the cable.
to install reverse the procedure.
09-25-2015 06:58 PM
