Alternator Appointment
Old Dec 21, 2009 | 04:06 PM
gnrpatience's Avatar
gnrpatience
Default Alternator Appointment
So i already have my appointment to test my alternator, but how do i know that is ok, what are the correct levels for the alternator, dont want stealership to lie and i dont know they are lying.
What are the correct numbers for alternator and battery tests ?
Thanks
Old Dec 21, 2009 | 05:04 PM
NuclearMuscle523's Avatar
NuclearMuscle523
SCAM ALERT! This person is known around the internet for ripping people off. You've been warned.
If your car isn't dying, it's fine. And I think any voltage output higher than battery voltage is the range. Amp draw depends on running accessories.
Old Dec 21, 2009 | 05:26 PM
Lethaldosage423's Avatar
Lethaldosage423
i just got a new one...my car kept dying and it was whineing
and when my car was running, if i took off the negative battery terminal, the car would die.....it shouldnt do that so i knew what it was
Old Dec 22, 2009 | 12:41 PM
gnrpatience
Its not dying while running, but sometimes in the morning it seems it doesnt want to start, cranking is not alright feeling like it wont start.
Old Dec 22, 2009 | 06:08 PM
Boozshey's Avatar
Boozshey
Appointment why not just get a quick 30 second check from Autozone or something as a baseline test. Then make an appointment if something shows whack...
Old Dec 29, 2009 | 11:54 AM
gnrpatience
Well we dont have Autozone in Mexico City =( so i need to go with dealership to test alternatertor and battery.
Old Dec 29, 2009 | 06:19 PM
brunobluto's Avatar
brunobluto
A quick simple test would be to get or borrow a cheap volt/ohm meter and hook it up to the battery. With the car off it should read around 12.5 volts. while running it should be around 13.5 to 14 volts if the alternator is working right.
Old Dec 30, 2009 | 01:21 AM
bigblue95z's Avatar
bigblue95z
Taking the negative battery cable off while running is never a good idea. Maybe 'back in the day', but that is a BAD idea with all the electronic devices on modern cars.
Old Dec 30, 2009 | 07:04 PM
yamahadm250's Avatar
yamahadm250
good advice,the fastest way to kjill a alternator is to remove one of the cables with the engine running.the voltage spike can kill computers also.
4cylinderplus2
Oct 9, 2020 07:45 PM
Golfsito
Oct 6, 2015 11:02 AM
MasterLanMan
Sep 26, 2015 10:03 AM
04stangman
Sep 17, 2015 01:45 PM
mrmrultimate
Texas Regional Chapter
Sep 10, 2015 09:43 AM
