Removing Headlight Switch
Old Dec 24, 2009 | 04:26 PM
Goldenpony's Avatar
Goldenpony
Default Removing Headlight Switch
Can anybody tell me how to remove the headlight switch out of my '06 GT? I know it's probably easy, but I don't want to break anything. I want to try to replace the illumination bulb.
Old Dec 24, 2009 | 04:35 PM
chopper_man's Avatar
chopper_man
Just gently pry it forwards, comes right out. You "could" use the widest flat blade screw driver you have, I'd highly recomend picking up a set of plastic interior trim tools, they are worth their weight in gold.
Old Dec 24, 2009 | 05:48 PM
hammeron's Avatar
hammeron
chopper man is right, you can pry it out
pretty easily....
the second time around, i figured out that you can
also just reach up and push it out from the
inside....
Old Dec 24, 2009 | 09:16 PM
Goldenpony's Avatar
Goldenpony
Thanks guys. Actually, I have a set of the plastic interior tools - I'll use them.
Old Dec 24, 2009 | 09:17 PM
alkemist's Avatar
alkemist
This info came in handy, I need to replace my bulb when I get my mustang back from the shop
Oh, and there is no stock bulb that you can use to replace it.. you can though buy a bulb at radioshack that gets the job done but does not have the same light output. Ford wants you to buy their whole panel D:
https://mustangforums.com/forum/2005...itch-bulb.html
StalkerGT
Nov 28, 2015 03:09 PM
jhawkr
Oct 30, 2015 01:55 PM
Colin Ringle
Sep 15, 2015 09:27 PM
wawagner82
Sep 13, 2015 09:02 AM
vintageaion
Sep 8, 2015 10:45 AM
