need some freaking help
Old Jan 1, 2010 | 11:43 PM
dominatortheterrible's Avatar
dont worry about it guys ill get it worked out..hell this is the only problem ive encounterd with this car so far and im close to the 50,000 mile mark
Old Jan 2, 2010 | 02:20 AM
Tylus's Avatar
Tylus
Originally Posted by Nuke
Sounds like you're not getting a chance to get all the moisture out. As much as I don't like WD40, it WILL displace water. Try spraying it into the lock thru the tube AFTER the car has sat in the sun a little. You want any ice to have melted. Wiggle the tube a little while you spray. Also spray some into the lock mechanism on the door jam as best you can. Then, after a few days w/o any more rain, I'd spray with Lock-EZ which contains graphite to relubricate the lock.
I'm assuming the FOB doesn't work, either?
what he said
you have moisture in there.
use the WD-40 to get it out
Old Jan 2, 2010 | 09:00 AM
alkemist's Avatar
alkemist
lol, climbing through the trunk. On the bright side, you were able to get in
Anyways.. what the other folks said, give that a whirl.
Old Jan 2, 2010 | 09:17 AM
ski's Avatar
ski
Heh.
Apparently you were the one that was worried. If you weren't, then you wouldn't have come here asking for help. Right?
Old Jan 2, 2010 | 09:59 AM
pascal's Avatar
pascal
S197 Section Modder-ator
Put some electrical tape to cover the key slot when you park your car.
Oh, and I hope your fob works, if not, you need to have your head examined.
Unless something is jammed in there...
Old Jan 2, 2010 | 12:04 PM
157dB's Avatar
157dB
Cut & Paste Expert
elaborate? ok i stick the key in and it doesnt turn..as ive stated the deicer doesnt work but maybe half the ime..i even put some regular lubricating oil in..only have the problem when it gets in the 20s and below
You need to DOMINATE the key fob.
The Remote Keyless Entry is KING.
Remotes are available on eBay for less then $10
and you can program them yourself....
DOMINATE the situation instead of it DOMINATING you.
I have never used the key lock once during my 3 years of ownership.
That includes the trunk lock. I also dont have any paint scratches
in those areas as well...
Dont use WD-40 on anything. Period.
IT EXAPORATES AND LEAVES A STICKY MESS THAT WILL
CAUSE LOCK PROBLEMS EVEN WHEN ITS WARM OUT.
Get the proper lock lubricant.
Graphite. iT DISPLACES MOISTURE AND PREVENT FUTURE FREEZE-UPS.
iTS EXPLAINED IN DETAIL IN THE oWNERS mANUAL
And avoid the lock when you are pressure washing the vehicle.
Old Jan 2, 2010 | 12:40 PM
i must be coordinated because ive been using a key for over a year on this car and havent had a scratch yet,i would attempt to dominate the fob if i knew what that is....got a link for the supposed 10 dollar remote?
Old Jan 2, 2010 | 12:42 PM
Originally Posted by ski
Heh.
looks like someone woke up on the ******* part of the bed...
Old Jan 2, 2010 | 12:53 PM
alkemist's Avatar
alkemist
A key fob looks like this:
http://cgi.ebay.com/ebaymotors/ws/eB...d=370294082063
It's a remote keyless entry system.. If you don't have a couple.. search on ebay. You can easily program it yourself. Instructions are in the manual.. if you don't have one, you can search online.. I did not look into the details on the fob in that link, it's just for the picture.
pascal's Avatar
pascal
Keep it civil dude, I think you might have stepped on your ******* side as well.
ski should have phrased his post maybe in a different way but no need to call him names.
With the few facts you're giving us, you're not looking too bright yourself at the moment...
A key fob is simply the remote device that you're missing apparently, if I understand your posts correctly...
In that case, E-bay is your friend on that one...
