Window issue and some error codes
Old Jan 5, 2010 | 02:55 PM
Dame83's Avatar
Dame83
Default Window issue and some error codes
Ok, so I picked up my car yesterday from the shop, was involved in an accident a few weeks ago, some front end damage, spinning around, fun stuff, lol.
thread for accident with pics, before and after.
https://mustangforums.com/forum/2005...the-stang.html
So now i have two issues, my driver side window and two trouble codes.
The Window issue: Cannot close door with window up, it dosent stop short of the top like its supposed to ( does not leave that little space so when door is closed, window will go up on its own). Unable to do the reinitialize suggested in the manual cause the window will not stay up to hold for two seconds, just goes right back down when it reaches the top. Any insight will help.
Codes: Checked codes with my Diablo Predator, got back: P2103: unknown, p1233: Fuel pump driver module disabled or offline and p1000: odb systems readiness test not complete
not worried bout the p1000, but more on the p2103 & p1233.
Thanks in advance for any insight
Car has bama 93 octane tune and Steeda CAI.
Old Jan 6, 2010 | 03:25 PM
Dame83's Avatar
Dame83
Anybody??
Old Jan 6, 2010 | 03:32 PM
alkemist's Avatar
alkemist
I thought you took it back to the shop? Sorry, not a useful comment Just wondering what happened with that.
EDIT: Searched on the internet: P2103 Throttle Actuator Control Motor Circuit High
http://klmperformance.com/diagnostic...codes-ford.htm
Do you think the stealership reset your computer?
Old Jan 6, 2010 | 03:35 PM
Nuke's Avatar
Nuke
As far as the window, do the recalibration procedure described in the OM. Can't begin to say about those codes other than it may have something to do with the shop having the battery disconnected. I assume the car is running fine otherwise? I'd disconnect the battery again for about 20-30 minutes, then do the window recal if necessary and see if you still get those codes.
Old Jan 6, 2010 | 03:50 PM
Dame83's Avatar
Dame83
I havent been able to make it back up there because of work, maybe i can make it to the shop on sat.
I reloaded my tune yesterday, seems to be running better after i did that. So it runs fine as it did before the accident. Dont think the dealer reset it, prolly just had the battery disconnect for a long time.
Tried the re-cal procedure, doesnt work. Window doesnt stay up, it goes right back down so i cant hold for 2 seconds.
Old Jan 6, 2010 | 10:07 PM
Dame83's Avatar
Dame83
Checked for codes just now, they are gone. Weird but fine with me. Tried the window thing, still not right. Im really not satisfied at all with some things that the shop did, my window, the headlights are not fitted correctly with the bumper, so the lights are pointing downward so i cant see that good at night. Boy I wish i woulda got that ladies plates. I really would stalk her and egg her car every morning.
Old Jan 6, 2010 | 10:09 PM
alkemist's Avatar
alkemist
Don't forget to toilet paper her trees.
Sucks having to go back. Hope they fix the issues for you.
Old Jan 7, 2010 | 10:03 AM
Mpaint99's Avatar
Mpaint99
Dont laugh but check your battery. My Drivers side window started to malfunction and the battery was not holding a full charge. Replaced battery and window worked perfect again with no future issues.
1TUFF302
Nov 5, 2015 04:02 PM
MusicCity615
Sep 12, 2015 07:05 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
zanemoseley
Sep 6, 2015 12:58 PM
