How big of a difference does Gas make?
Correct, the '10 GT's use a tune similiar to the Bullitt and will pick up some minor gains as howarmat mentioned. A good aftermarket tune should tack another roughly 12-15 RWHP with the higher octane fuel over the stock tune with the same fuel.
But I think I don't fully understand... You were racing. But didn't go over 4k RPM... and didn't go over 55 MPH? I'm over 55 before I shift out of 2nd... How do you even have time to tell he was casually pulling on you?
I find more mpg's along with a little more pep, I can say this cause I have gone from stock CAI, to stock CAI W/ K&N dropin with a 87 tune, then going to a JLT CAI with another 87 tune, and differ, octanes will produce results even if small, just like everyone that dumps the stock drive shaft for a one piece shaft.
sounds like i should bite the bullet and just start using 93 octane.
I don't think you could gain much without a tune going from 87 to 93. Time for a tune.
Was the "race" from a dig?
A mere octane change is not enough to put you past the 370z, however if you raced from a rolling kick down you would take him.. Our cars spin more tire then the z because v8 makes more low end torque. A rolling kick down when both cars already have traction is where the real winner shines..If you want to be certain, get a tune, a k/n drop in filter, a real axle back exhaust and a lightweight 1 piece drive shaft and you will be set...
