Warranty expiring soon
I would suggest you take it to a mechanic you trust and have him check everything. My mechanic found a leaky shock. I called the dealer and ordered the shock. made an appt to have it replaced. The service guy almost crapped his drawers when i told him i already ordered the shock and he has it in stock.
Check out the TSBs here;
https://mustangforums.com/forum/2005...tech-info.html
I had the TSB 06-25-15 Aluminum Body Panels Corrosion. Here are some pictures of my hood before it was fixed.
Do check under your hood. It may look like the paint is blistering or bubbling but it's the TSB.
Battery coverage only extends if the battery throws a special code that is warantable (spelling?). Just because the battery appears sluggish, if they throw it on their tester and it doesn't reflect the code, they won't cover it.
I had one go out (battery) and they went through the testing process with me. It takes between 30 minutes and 4 hours...
KingRando
10-02-2015 08:06 AM
