New! Quick questions
Old Feb 22, 2010 | 11:12 PM
odiaz's Avatar
odiaz
one other problems that was common on the '05s was a problem with the trottlebody. There was a TSB on it. After driving for a while the car would stall. I had to have this fixed in my car.
You didn't mention if you had a coupe or a convertible. Another problem with the convertibles was that one of the top bows would rub against the the material and wear a hole on the left side from the inside out. There was a tsb for this also. I was lucky, I'm one of those older guys that takes immaculate care of his car and fixed this before it became an issue. If you don't show any signs of wear, you should put some black duct tape on the tip of the top bow to act as an insulator and protect the top. This was the "fix" recommended in the TSB to protect the new tops from succoming to the same problem.
Old Feb 23, 2010 | 09:59 AM
jgaither's Avatar
jgaither
I got a coupe, its white with red leather interior...I'll get posts up as soon as i can figure out my space age smart phone to sync up with my laptop : ) Thanks for all the responses, if the aux isnt in the armrest console or glovebox where else is it? or do i just have the button and no aux port.
Old Feb 23, 2010 | 09:17 PM
odiaz's Avatar
odiaz
The 2005 did not have an aux port. The shaker 500 has a button for it but the wiring harnass does not have any support for it. Some have installed a "P.I.E." adaptor. IT's available form crutchfield.
http://www.crutchfield.com/p_469FRD4...er.html?tp=120
Old Feb 23, 2010 | 10:12 PM
Nuke's Avatar
Nuke
Read thru the TSB's in one of the stickies to this forum. That'll provide you about 90% of the issues with these cars. Don't be alarmed at the LONNNNG list of TSB's. But pay particular attention to the water leak and fuel pump TSB's.
tmdm
May 2, 2021 02:49 PM
svfetter
Oct 5, 2015 11:39 AM
treesloth
Sep 28, 2015 07:03 AM
Big Al's 03
Sep 15, 2015 09:05 AM
Mustangmalo
Sep 6, 2015 05:22 PM
