Pretty sure my passenger side strut or upper strut mount is busted.
I have loud loose bolt rattling sound upfront. While investigating with the hood up, I can see the top of the shock shaft move independently from the car when I lift up the car. The banging sound happens at the same time and is definitely coming from the same location. The strut mount bolts are not loose.
Not sure what you mean by "which one". Which strut mount? You have to replace them as a set anyway. You might want to get a set of the GT500 mounts. They're reasonable, and stronger.
I had a clunking sound from the front too. I recently replaced my strut mounds with the Steeda HD mounts. No more clunking up front. I did have to get a front end alignment, but the noise is gone.
