Shaftmasters experience
I ordered a driveshaft from Shaftmasters today. If I am impressed with it, I will be ordering 12 more from them. I will post my results after the install.
The stock pinion angle on a non-lowered car is about -1 degree.
Timmbo, I'm curious as to your experience with the driveshaft above your stated sweet spot of 80 mph. I would say EXACTLY what you said about the driveshaft being perfect for sub-80mph driving. It's odd you say that too because I thought the exact same thing driving tonight.
After another drive, it's just fantastic under 80 mph. Above 80, there is increased sound and tactile resonance that borders on vibration. There are twinges of heavy vibrations that are felt around 105-110.
I think your concerns are valid and I know Dave at Shaftmasters will take care of you. Like I said before you just have to weigh things out like what speed you spend the majority or your time driving and is it at those speeds where you find the shaft acceptable. I truly believe there are compromises to be made here considering the one piece aftermarket design when actually the car was engineered for a two piece for a good reason I'm sure. Obviously a one piece is much cheaper than a two piece with cv joints and a center bearing. And you know Ford as well as other manufacturers like to cut cost where they can. So you know Ford required the use of the more expensive two piece design to solve and angle problem or reasonant sound wave problem at all rpms at all speeds. I'm no engineer but it makes sense.
Yep. But it's not too bad. I can comfortably say though that I rarely if ever hit 90+ mph so it's really not an issue for me because at 80mph and below where I drive just about all the time its perfect.
i run 235/50/18s stock. the circumference of my tire is approximately 86.08 inches. @ 85 mph, i'm going approximately 1496 inches per second which means the tires are making complete revolutions at a rate of 17.38 per second. multiply that by 4.10, and you get driveshaft rotations per second at about 71.26...4275.6 driveshaft rotations per minute. that's a lot...It really kinda puts things in perspective a bit. Even assuming that the driveshaft is completely balanced to spec (as I have believed all along), the tolerances are extremely low for all the other components of the rear suspension as well as the FRPP rear gears.
I dropped it in 4th gear on the highway to make a pass and WOW did it go! It just GOES...I was extremely impressed.
