Spark plug index washers
Anyone know where I can buy index washers for my 06 Mustang spark plugs? Reason I'm asking is because sometimes when I floor my car and kick in the boost I have one cylinder where the piston likes to hit the electrode on my spark plug and short it out.
How do you know that's happening? If it was, you'd see it all the time, not just when you're in boost. The max travel of the piston and the location of the spark plug don't change with RPMs.
it's probably more likely that you have a bad plug and/or the wrong gap and it's not sparking with the increased resistance of the extra cylinder pressure. I know Kenne Bell suggests upgrading the ignition at 15 psi. it's possible an aging ignition could need some help at a lower boost level, just an idea.
hummm, try going to a .030" gap and if that doesn't work then a .028" gap. sometimes a small change in the gap can make a big difference and it takes a little experimenting. KB suggest a .025" gap at 15psi, not sure what they suggest below that though, they just said to go one range colder.
If your piston is deflecting enough at boost to hit the electrode,
you have way bigger problems...
BTW, The electrode is in the center and the ground
is what you adjust for spark gap...
Too much ground electrode heat and it turns plastic and
bends where ever it wants to....
jwog666
12-27-2021 08:09 PM
breaking
10-02-2015 01:27 PM
10-01-2015 09:11 PM
