Cervini's '67 Hood Pix
#31
well I just got mine outs the shop so here's a pic.
The hood locks look great but are compressing the two pieces of fiberglass that make the hood. I am working on a solution that evolves cutting pieces of rubber to fill in the gap. It seems to be working. I had the body shop mount them in the hood and it looks like the right one is over lapping where the ram air ducting is going to go. I hope to work on that this week and get this project completed.
#32
Looks great! I can see what you mean about the hood locks compressing the fiberglass in the first picture.
#34
Nice Vert, that hood looks sweet!!!!!! I had the same problem with my hood locks, I just didnt wrench down too hard on the bolts and so far no problem. Post some pics when you do the ram air. I would like to know if it will clear the blower and if I can modify it to work with its intake.
#35
Thanks for the complements
The previous owner added the handle but i hear you can get them on ebay.
Will do, I have been looking at the same thing, well kinda, The more I look at it it should work with any intake that mounts in the same area as the air box.
#36
more pics as promised
hood before paint
the scoop area had a blimish or two but they are hard to see it in the photo
Ram Air duct work
This is the part that you have too attach to the stock air duct.
Stock air box after the first Cut.
Sorry that i didnt get more pics of the process.
This is a picture of under the hood missing the stock air box.
THis is under the hood with the air box installed after the ram air reciver is installed.
Ram air air box installed
hood before paint
Ram Air duct work
#39
I'm thinking it won't clear the blower because Whipple even tells you to remove the stock hood liner because it will rub. The ram air kit most likely sits lower than the hood liner did.
wishinsky
09-21-2015 09:48 AM
